It is currently Thu Jul 17, 2025 9:42 pm
[ 7 posts ] |
Fuel solenoid on stock carb.
banded-mallard
Anyone evey had any issues with this. I think mine is about to go out. Starting to stick. I am running premium fuel but when I acts up, I pull it, push in the plunger, screw it back in, and run the piss out of it.
Thu Oct 04, 2012 8:00 am |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: Fuel solenoid on stock carb.
So just remove it, replace it with a bolt & keep rollin
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Thu Oct 04, 2012 8:16 am |
cb5331
x2
Thu Oct 04, 2012 8:30 am |
banded-mallard
It doesn't effect anything? Fuel rate? What about the black & white wires to the quick connect?
Thu Oct 04, 2012 11:58 am |
cb5331
It is an anti-backfire solenoid. It's just a pluger that cuts off the fuel when the key is off. It is there to help prevent backfirinig when you turn the key off at high rpm's (in other applications...lawnmowers, generators). We throttle our motors down before turning the key off. It is not needed, but can get gummed up and cause problems. Just pull it and put a bolt in it's place. Tie the wires up out of the way or remove them completely if you wish.
Thu Oct 04, 2012 12:28 pm |
banded-mallard
10-4 thanks
Thu Oct 04, 2012 12:42 pm |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
I hate those things. I tore my engine apart 2 weeks ago put it back together and it would start. After an hour and 9 beers I realized I didn't plug mine back in.
_________________ You have your whole life to be an idiot, take a day off!
Thu Oct 04, 2012 6:42 pm |
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 117 guests |
