It is currently Sun Apr 12, 2026 9:27 am
Reply to topic  [ 16 posts ]
 White Smoke?
Post White Smoke?
i have a 27 kohler and when i squeeze the throttle i get a huge cloud of white smoke. Anyone have any ideas?
Fri Aug 07, 2009 3:45 pm
Post Re: White Smoke?
White smoke usually means your burning oil if I'm not mistakin
23 hp gdlt pushin the 14ft NoWeld "aka" the black pearl
35 hp gdsd pushin a 16/60 go devil boat
Fri Aug 07, 2009 9:12 pm
Sat Aug 08, 2009 11:19 am
had the same issue, seals where bad, burning oil. ended up having to get a new engine
1856 twin 23 GDLT
Sat Aug 08, 2009 5:28 pm
pour a little kerosene in da caborator if you really want to see white smoke :lol: :lol: :lol:
Sat Aug 08, 2009 6:00 pm
Maybe you have the Cheech and Chong edition? :lol:
White smoke isn't good.
Sun Aug 09, 2009 4:44 am
blue smoke should be oil. is it very white or does it have a lil blueish color. how many hours is on the engine?
BUCK OFAMA
Mon Aug 10, 2009 7:18 pm
Could be a head gasket sucking coolant into the cylinder and burning it.
Tue Aug 11, 2009 7:39 am
Tue Aug 11, 2009 7:53 am
White smoke is usually coolant entering the combustion chamber on a liquid cooled engine.
I had my New motor blow white smoke a couple times and it never happend again, but it had a bluish tint to it aswell. Its fine now. Maybe sniff the exhaust somewhat to figure out if it is oil entering the conbustion chamber. Rings off the top of my head will let oil in the chamber.
Do these engines have a vent from the crankcase to the intake and it can be letting oil in the chamer?
Tue Aug 11, 2009 8:26 am
vent it does. That is a possibilty.
BUCK OFAMA
Tue Aug 11, 2009 9:54 pm
I am no expert by any means but I am confused......just where is that coolant coming from? Is it in the air running across your air cooled motor or did you hook up a radiator?
1846 Drop Deck GTB w/ 35GTR and some Hoyt voodoo on it like dat!
Wed Aug 12, 2009 8:25 pm
blue=oil
white=usually bad air/fuel ratio might be dumpn too much fuel
Wed Aug 12, 2009 9:07 pm
do you leave the gas tank in the boat out side? if so change the gas could have water in it that with make it about blow white smoke
16 X 54 Prodrive boat with 32hp Prodrive stage 1 motor runs 33mph
Thu Aug 13, 2009 12:36 am
Put yer face in the myrtles.
Wed Aug 19, 2009 7:46 pm
If you were dumping to much fuel in it would be black smoke. White would be it's running lean. Blueish white smoke is oil. My boat was black smoking when my carb needed adjusting
Wed Aug 19, 2009 8:15 pm
