It is currently Fri Mar 20, 2026 2:11 pm
Reply to topic  [ 29 posts ]
 spark plugs
Post spark plugs
whats the best kind of spark plugs for the mud buddy vanguard 45 mag?
Sat Oct 27, 2012 8:35 pm
Post Re: spark plugs
champion, NGK
Sat Oct 27, 2012 8:47 pm
Agreed, I have had better luck with NGK in most engines but Champions are pretty good. Dont wast money on anything fancy or advertising 20% more power or anything like that. In reality you cannot feel the difference between a standard plug and a $12 plug other than in your wallet when you change them every season.
Mon Oct 29, 2012 1:56 pm
I don't know if it's just coincidence or what, but last 3 motors I've seen with fouled plugs were all NGK. I've had best luck with Champion and Autolite
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Oct 29, 2012 3:29 pm
Mon Oct 29, 2012 3:32 pm
I like champion the best. Seem to get a better read for jetting too
1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
Mon Oct 29, 2012 3:52 pm
I run NGK's and haven't had a problem.
Mon Oct 29, 2012 5:42 pm
Now i will tell you this if they aren't gapped right and 7 times out of 10 right out of the box they are not, then yeah you will see some serious fouling but when gapped right they are great. I ran them in my motor cross bikes which were four stroke
Mon Oct 29, 2012 5:48 pm
Mon Oct 29, 2012 5:53 pm
Mon Oct 29, 2012 5:58 pm
Gapping mine at .30
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Oct 29, 2012 6:00 pm
You can run what ever you want, i found that through my motor those 2 worked the best
Mon Oct 29, 2012 6:11 pm
I've been running stock plugs.
Haven't noticed a bit of difference.
Mon Oct 29, 2012 6:15 pm
WC 1848 Bateau w/ 36 PD FPR
Mon Oct 29, 2012 6:20 pm
I put new stickers on mine & gained .0896521 mph!!!
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Oct 29, 2012 8:07 pm
I just spray ether in the carb and it hauls ass and turns some good rpms.
Mon Oct 29, 2012 8:35 pm
But seriously i just run some champions and they fine. It's a spark plug and a Briggs engine it's not rocket science
Mon Oct 29, 2012 8:40 pm
champions are good plugs
x2^^
B. MacDonald
Tue Oct 30, 2012 11:23 am
Autolite 3923's
Tue Oct 30, 2012 12:51 pm
Y'all recommend still using thoes plugs with a highly moded motor
2010 gtr cdi with a stage 2 pushing a 18x46 home made HEAVY DUTY boat
Tue Oct 30, 2012 1:20 pm
Yes
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Oct 30, 2012 2:00 pm
Found this on another thread:
Champion-RC14YC
NGK-ZFR5F-11
BOSCH-7527 or FR8 DC
gapped at .030
Tue Oct 30, 2012 2:11 pm
Why the Bosch has two diffrent ones
Tue Oct 30, 2012 3:29 pm
Electricity will take the path of least resistance. Those fancy multi prong plugs will just mak eyour wallet lighter.
Tue Oct 30, 2012 3:43 pm
Does a 31 use the same plugs mentioned above?
Tue Oct 30, 2012 4:08 pm
My dad runs the app3923's gapped at 35 in his 32 which is the same as your 31. I run them in my 36 as well. Haven't had a lick of trouble out of either motor.
Tue Oct 30, 2012 4:56 pm
I have a stock GTR 35 (carb) motor and live in a cold climate. I just changed my plugs to RC14YC's after reading on the Briggs website that they could be better for cold weather starting and after seeing that part number referenced on several maintenance posts here. I gapped them to 0.030.
When I pulled the old plugs I saw they are RC12YC, which is my understanding run colder and help prevent pre-detonation on modded engines.
Would this be a factor in harder starts for cold weather? When would you choose the hotter plug (i.e. what should I be looking for--burned plugs, plugs smelling like gas, etc.)?
Thanks
Fri Nov 02, 2018 8:37 am
Consider the 14 a small step warmer plug. This does not mean it's a hotter spark. The tip of the spark plug runs a little warmer to keep carbon burned off. Run them and see if they help. It's not much of a heat change from a 12 to a 14
Tue Nov 06, 2018 1:30 am
Tue Nov 06, 2018 6:36 am
