It is currently Mon Apr 06, 2026 2:11 pm
Reply to topic  [ 9 posts ]
 speed sound right
Post speed sound right
Guys i'm fairly new to mmt ,but i have been reading as a guest for months and really appreciate all the knowledge you all have to share. I recently bought a 35hp backwater LS that I put on my f&f 1548 with small pods 16" transom and true flat hull with runners. I am getting 23-25mph on average with 6gal gas, 80lb deep cycle battery, flip blind, me(190lbs) and a few back up essentials in case something breaks. Does this sound like respectable speeds? Also if it helps i'm running a 9x8 prop new
Thu Nov 08, 2012 10:31 pm
Post Re: speed sound right
I would think your prop is pretty small. I would think you would be running a 10" or 11" prop with 35hp and a small boat.
Thu Nov 08, 2012 10:35 pm
What does your prop measure from tip to tip, should be 12 1/4", that 35 should be turning a big blade no matter size of boat, measure it from tip to tip and post it up, if you in the 11" range it needs to be replaced
Thu Nov 08, 2012 11:58 pm
Welcome. I'm a newbie too, the collective knowledge is worth signing on for.
Quote:
Fri Nov 09, 2012 3:03 am
The 9X8 is the correct prop for a Back Water longtail. NO longtail runs a 11 or 12" prop. MB experimented with a 11" with their new super longtail, but went to a 10".
Speeds sound great for a longtail. Sounds like you have a nice set up.
MB 35hp LT/1754 Grizzly
Fri Nov 09, 2012 10:14 am
Prop measures 9" across by 2 3/4" front to back going to get a tiny tach to measure rpm's in the morning it helped that I finally got all the leaks out of the pods and I'm gonna do the break in oil change as well boat measures 16'8" long with pods with 1/8th in hull
Fri Nov 09, 2012 5:49 pm
Here's a pic of my rig
Fri Nov 09, 2012 5:57 pm
Sorry i saw 35 and assumed it was a surface drive
Got the 35 cuz I wanted the extra torque/thrust to haul my gear and hunting buddies around with usually run 3 guys 4 doz dekes 4 spinning wings plus gear guns and occasionally a dog
Fri Nov 09, 2012 6:50 pm
