It is currently Sun Apr 12, 2026 1:56 pm
Reply to topic  [ 12 posts ]
 Carb Upgrade
Post Carb Upgrade
What's done about the governor setup and linkage when you go from a stock carb to a Mikuni?
Thu Aug 20, 2009 9:17 pm
Post Re: Carb Upgrade
There is a part that goes on it to keep it locked WFO I believe. Hence the need for a rev limiter.
18x48 Charles Leonard / 36PD
Thu Aug 20, 2009 9:55 pm
The BPS kit has an aluminum block clamp with an arm on it to lock the governor shaft on the top of the motor fully CCW, basically disengaged.
Fri Aug 21, 2009 2:00 am
Thanks for the info
Sat Aug 22, 2009 10:01 pm
Don't mistake my kindness for weakness, my ability to look over things as ignorance - but make no mistake, when I've had enough, I'm Coming After you. Watch Your Back....lol
Mon Aug 24, 2009 7:59 am
Funny you should mention that cause I was thinking the same thing. Somw way
you could lock that existing arm at a specific location depending on the RPM you want?
Mon Aug 24, 2009 9:26 am
Mon Aug 24, 2009 9:32 am
You could do it with a spring and a kill switch. From what I have been told the governor arm is activated by oil pressue of some sort. The arm pulls the throttle closed it doesn't stop the enine internally. Thats why there are so many springs on the stock linkage. Springs with different tensions pull against each other until the governor lever pulls on one harder than the others to "let off the gas". If you had a certain tension spring and a micro switch the spring could hold the lever from activating the switch(that would be connected to the kill switch) which would kill spark (same as fancy rev limiter) It would take some experimenting but is definitely doable and could be easily adjusted with a small bracket once the proper strength spring is found.
MarshMellow Performance
Wed Aug 26, 2009 9:52 am
Wed Aug 26, 2009 9:56 am
Wed Aug 26, 2009 10:01 am
Wed Aug 26, 2009 10:07 am
The current electronic rev limiter being sold is the Rube Goldberg version. :mrgreen:
Wed Aug 26, 2009 10:15 am
