It is currently Fri Apr 10, 2026 6:48 am
[ 3 posts ] |
poke_chop666
Joined: Sat Apr 06, 2013 12:07 am Posts: 487 Location: port barre,la
 shaft size question.
I have a question about long tail shaft sizes. I have a 5 hp with a 3/4" output shaft and a 3/4" shaft to the prop. Does bigger motors such as the 15 or 20 or such have a 3/4" shaft to prop also or a bigger one. I know output size will be different but is the prop shaft also? I want to put a bigger motor and prop but worried I would have to change shafts also.
_________________ 25 yamaha pushing a 1642 welded flat 20 hp go-devil longtail for hunting.
| Tue Apr 09, 2013 8:36 pm |
FRANKtheTAU
Joined: Thu Dec 29, 2011 10:30 pm Posts: 1386 Location: West TN
 Re: shaft size question.
Same shaft size. Doubt you'll be able to get a motor much bigger that'll still fit your frame.
_________________ 40 Backwater SWOMP Lite / 1752 Alweld Mud
| Tue Apr 09, 2013 9:05 pm |
poke_chop666
Ill weld a bigger plate on it and adjust the cavitation plate. Jist wasn't sure about the shaft. Didn't think a 3/4" shaft would hold up to the abuse of a 25.
| Tue Apr 09, 2013 9:11 pm |
[ 3 posts ] |
