It is currently Thu Apr 02, 2026 10:35 am
Reply to topic  [ 31 posts ]
 Changing Prop Broken Shaft...
Post Changing Prop Broken Shaft...
Has anyone on here ever broken a shaft where the prop threads are when changing props?
Sun Sep 20, 2009 7:56 am
Post Re: Changing Prop Broken Shaft...
Just had one break on my 25hp GDLT had to buy a new prop ($225) and shaft to get it back going, I am going to have to get a machine shop to get the broken shaft out of my old prop.
16x44 GD boat w/25hp GDLT
Mon Sep 21, 2009 2:16 pm
Why on earth would they thread a shaft instead of spline it?
Mon Sep 21, 2009 3:00 pm
It's easier.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Mon Sep 21, 2009 5:47 pm
>>>so when ya hit something the prop spins a little instead of breakin the splines!
Mon Sep 21, 2009 5:55 pm
Mon Sep 21, 2009 6:00 pm
Profile YIM
Actually, the shaft thrusts into the prop. If you hit anything you are jamming it on tighter.
Mon Sep 21, 2009 6:09 pm
Mon Sep 21, 2009 6:12 pm
Profile YIM
Mon Sep 21, 2009 6:16 pm
Mon Sep 21, 2009 6:25 pm
Profile YIM
Yeah, I know you supposed to hear a pop. But, you don't hear a pop until you pull it out the water or let off the gas. This is because the shaft then spins faster than the prop causing it to break loose. Go look at your motor, think about, and get back with me.
Mon Sep 21, 2009 7:02 pm
i am looking at it doesnt do anything i amm thinking about it and have came to the conclusion that u are wrong :lol: :lol: :lol: :lol:
Mon Sep 21, 2009 7:07 pm
Profile YIM
If you are putting your prop on and you push on the leading edge it is tightening your prop, correct? So what is the fukin difference if you hit an object with the leading edge? :twisted:
Mon Sep 21, 2009 7:10 pm
Not wantin to disturb yall argument but...... the shaft has left handed threads and when I hit somethin with mine, it tightens the hell out of the prop. My prop dont (float) anymore.
Mon Sep 21, 2009 7:11 pm
Mon Sep 21, 2009 7:12 pm
Profile YIM
Unless, Go-devil changed within the past 5 yrs. They are now right handed. Righty tighty, lefty losey. Took my prop off about a week ago and it's still right-handed just like the day I bought it. May be different rotation for the 27 but I know if you push on the leading edge on mine and the 16 it's tightening the prop.
Mon Sep 21, 2009 7:14 pm
Ya know what I meant. Ya hit somethin, prop tightens.
Mon Sep 21, 2009 7:15 pm
Mon Sep 21, 2009 7:21 pm
Mon Sep 21, 2009 7:23 pm
Profile YIM
Mon Sep 21, 2009 7:24 pm
Profile YIM
Mon Sep 21, 2009 7:25 pm
Profile YIM
I ain't gonna fight over dis chit. I know what mine does and don't really give a chit what the others do. I know mine tightens and if I hit something it makes it a b@#ch to get off. I also know it's right-handed just like every other bolt on every other piece of equipment I work on on a daily basis. Push on the leading edge of your prop and if it tightens it tightens if it doesn't, it doesn't. I really don't give a chit. No offense.
Mon Sep 21, 2009 7:31 pm
Mon Sep 21, 2009 7:33 pm
Profile YIM
Ya really think it would break the splines?
Mon Sep 21, 2009 8:38 pm
I'm thinkin about having my next one splined cause that SOB was on there so tight I broke my shaft trying to take the prop off!!!
Mon Sep 21, 2009 8:39 pm
you could make yourself a prop tool with a nut, piece of pipe, and two pieces of flatbar. Put a socket and impact on it and it will come right off.
Mon Sep 21, 2009 8:43 pm
Damn that is a good idea... Sounds like you might have changed a few of these bad boys? So what do you think about the splines?
Mon Sep 21, 2009 8:47 pm
Fuke it if ya got the tool.
Mon Sep 21, 2009 8:52 pm
And mine was a struggle the whole way until the shaft finally broke.
Mon Sep 21, 2009 8:53 pm
Mon Sep 21, 2009 8:55 pm
I have put them on with a marine taper and a key. Over time they also tighten up just like a morse taper and getting one off can also be very difficult.
Mark F. Cheney
on the Great Salt Lake marsh
Sun Oct 11, 2009 7:06 am
