It is currently Sun Dec 21, 2025 10:06 am
Reply to topic  [ 16 posts ]
 Which Motor works best for my boat
Post Which Motor works best for my boat
I have an 18x44 Go-Devil boat. It is not the SD Boat, but the older model. I would like to put a Surface Drive Engine on the boat.
1. Is there any negative to putting a surface drive on a boat that was built for a long tail?
I have this exact boat?
Would a GT35 or a Pro Drive have decent performance on this boat if I can add one? Thanks.
Tue Sep 22, 2009 11:27 am
Post Re: Which Motor works best for my boat
That seems like a very light built boat. But, if you already own it.. Put a Motor on it....
If you have the poling Platform, it will most likely have to come of.
You will need to measure your transom to insure proper height for either one of the two manufacturers you listed.
Tue Sep 22, 2009 11:44 am
I had a 36 pd on my 18x44
ran about 24-25 mph empty. (had a hook at the transom)
load carrying wasn't that great.
my new boat would out run that hull i had anyday.
watch out for the backwash with the short transom.
I will say that boat could turn on a dime at WFO
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Tue Sep 22, 2009 6:04 pm
Thanks for the responses. But, since I am a newbie, is WFO ---wide f'n open?
I was hoping with the boat empty, running a 35 gator tail I would at least get 27-28.
I stripped the foam out today, it was soaked. Going get some new foam on Saturday, should be 50 pounds lighter.
What kind of fuel tank do I need? I need 20 mile range round trip to access my lease. Will 6 gallons make it??? Thanks again gents
Tue Sep 22, 2009 7:39 pm
Tue Sep 22, 2009 7:45 pm
Profile YIM
EVT Stage 1 32PD on a 17x48PD
"I'm not a Republican because I grew up rich. I'm a Republican because I did'nt want to spend the rest of my life poor. Waiting for the goverment to rescue me."
Mike Huckabee
Thu Sep 24, 2009 2:07 am
go with a 36 pd. i had a go devil and the go devils cant hold a candle to them.. the prodrive have a neutral switch and reverse... i have a 1648 grizzly semi v and i had a 23hp godevil n only ran 7-9mph.. i purchased a 36 prodrive n ran 25mph with 3 big guys 2 boat batteries, 5 gallons of gas, 2 anchors.... pretty pleased with the prodrive
17x54 prodrive x series powered by 36hp prodrive..
Prodrive prostaffer
Timber ridge retriever
Sun Sep 27, 2009 6:45 pm
transom height and angle will come into play too...pretty sure most of those older boats have a 20 degree transom but not 100% sre on that
Its 18 foot long but being short transom, 44" wide bottom and round chines the PD is gonna sqaut the back of the boat alot
What terrain are you running? That'll be little better deciding factor I think
like someone already said get the biggest motor now and then worry bout the boat later
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Mon Sep 28, 2009 9:17 am
The boat has a short transom. Kyle at Gator Tail told me to get the transom raised to 21 inches, and he said the 35GTR would run great on that boat. I run this boat is stictly brackish marsh. Even on the dead of winter days, I still have some water in the ponds that I hunt. We will see, thanks for all of the replies on this post, most helpful.
Mon Sep 28, 2009 10:15 am
Mon Sep 28, 2009 3:01 pm
Darrel from Meraux has a 20x44 like that,he has a 31 lt and a 31 gt that he runs on it.He put a carb and new heads on the gt and it runs 30 with him and another guy in the boat.
Mon Sep 28, 2009 3:57 pm
what do you mean terrian? i have a 21in transom.
Prodrive prostaffer
Mon Sep 28, 2009 8:03 pm
terrain meaning.....timber, stumps, vegetation, hard sandy bottom, soft sandy bottom, soft mud, or any of those mixed in....etc
Pete Willett
Wed Sep 30, 2009 8:52 am
Get the most HP u can afford! And Don’t look Back!
16X60GD 27HP Surface Drive
Wed Sep 30, 2009 12:48 pm
Profile YIM WWW
i hunt hard n soft mud.... open water mainly......
Prodrive prostaffer
Wed Sep 30, 2009 3:42 pm
when we get alot of rain i hunt flooded corn field but that dont happen often..... go BIG or go home......36hp prodrive.... you will never regret it.... get them at abernathys in union city teneessee for 5795 out the door no taxes.... :D
Prodrive prostaffer
Wed Sep 30, 2009 3:45 pm
