It is currently Thu Apr 09, 2026 2:58 am
[ 4 posts ] |
AUgunner
 25 Kohler not running
I have been having issues with my 25 Kohler not wanting to run right. It doesn't appear to be getting fuel. I left the key on one night and I'm afraid I burnt up the fuel pump, so I replaced that. Then it would run somewhat but only on choke and then would spit and sputter, now it simply wont crank at all. I pulled the plugs and turned it over, it didn't blow out any gas at all. I then pulled the carb and cleaned it out really well, there was lots of gunk in the bowl and the needle valve was very seazed up. I got out all the junk, cleaned up the needle valve, and replaced the carb. Still nothing. I'm getting spark and still not getting gas. I'm at a loss here. I even went back and replaced the hose and priming bulb just for good measure.
The motor was running flawlessly the last time I took it out (when I left the key on and the fuel pump run for several hours), then when I tried to take it out the next time all hell broke loose and this is where I stand now. Any help would be greatly appreciated, I would really like to fix this myself instead of pay a small engine guy. Might do some upgrades while I'm working on it!
| Thu May 23, 2013 8:53 pm |
Cajunwannabe
Joined: Wed Jan 28, 2009 3:40 pm Posts: 188 Location: Wishing I was in SE La.
 Re: 25 Kohler not running
check the fuel shutoff solenoid. Sounds like its burnt up and stuck shut.
you can either spend money to replace or: Pro tip: Pull it out, cut the needle off and put it back in.
| Thu May 23, 2013 9:17 pm |
AUgunner
Well I checked that and it had already been cut, also pulled the carb and had it cleaned really well. It's still not running. I'm at a loss. Unless I can come up with more ideas, I'm going to be taking it to a mechanic.
| Sat Jun 01, 2013 4:55 pm |
guidry21
Joined: Thu Feb 14, 2013 1:33 pm Posts: 338 Location: galliano, la
it sounds stupid but check make sure your inline filter is on in the right direction had that problem on an outboard and it wouldn't run
_________________ 16x48 alweld 35 gtr
| Tue Jun 04, 2013 9:39 am |
[ 4 posts ] |
