It is currently Sun Jun 09, 2024 1:48 pm
Reply to topic  [ 130 posts ]  Go to page 1, 2, 3, 4  Next
 Gtr reverse brake pads
Post Gtr reverse brake pads
Should they be loose? The back one kinda sits off the rotor at an angle instead of squarely... Not sure if it's correct or notImageUploadedByTapatalk1371409802.539428.jpgImageUploadedByTapatalk1371409821.992847.jpgfront page sits right up against the rotor... It loosens when I let go of the lever
Sun Jun 16, 2013 1:12 pm
Post Re: Gtr reverse brake pads
they sit loosely
Sun Jun 16, 2013 1:43 pm
mine look the same way
- Mark Twain
Mon Jun 17, 2013 5:17 pm
Same here.
Mon Jun 17, 2013 5:28 pm
How often does a person have to replace them and where do you get them ?
Fri Jun 21, 2013 7:24 am
Kool-Aid Brigade
www.southernfowler.com
Fri Jun 21, 2013 7:44 am
Don't let them slip and they will last a very long time
17x48 extreme stage 2 GTR
Fri Jun 21, 2013 7:45 am
Mine do not sit at an angle like that, they are square with the caliper.
Fri Jun 21, 2013 7:54 am
- Mark Twain
Fri Jun 21, 2013 7:57 am
35 GTR - 1754 Extreme
Fri Jun 21, 2013 10:09 am
That first pic maybe the old style Owens is the newest they've got out
Fri Jun 21, 2013 10:34 am
Where are these on a pro-drive??
1648 gd hull flying in front of a stage 3 with fpr
Fri Jun 21, 2013 6:19 pm
- Mark Twain
Fri Jun 21, 2013 6:23 pm
The 3rd gen are pretty tight little to no slack or that's at least the 2013 model =-)
Fri Jun 21, 2013 6:49 pm
Reverse hasn't been used much and when it is used it's with a tight grip. Problem is the back side of the caliper is wearing just from the pad rattling around or something, not sure why. Only the back side is doing it.
Fri Jun 21, 2013 6:56 pm
- Mark Twain
Fri Jun 21, 2013 8:32 pm
I'm at the houseboat, it may be a few days..
Sat Jun 22, 2013 9:57 am
Idk, I bought it two weeks ago.
Sat Jun 22, 2013 10:17 am
Some of the Gen 2 calipers did that. Only way to stop it is putting a spring between the pads, pushing them apart. If you leave it like it is now, you'll be replacing that caliper soon.
The new caliper is different, the pads ride close to the disc, but not touching.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Jun 22, 2013 11:39 am
but the gen 3 pads last about 1/4 of the time the older gen 2 pads do
1944 skiff with 35 GTR
Sat Jun 22, 2013 12:18 pm
Can you buy pads at an auto store?
Sun Jun 23, 2013 7:58 pm
41 hrs on these pads is this normal inside one is wore out
Sun Jul 28, 2013 7:13 pm
dang Bigrich, 41 hrs and the pads look like that? You squeezing it tight enough?
HOTSAUCE170 wrote:
Sun Jul 28, 2013 7:21 pm
Only been in mud couple of times and I lock the rev when I do
Sun Jul 28, 2013 7:25 pm
As long as u have pad ur good just don't let it get metal to metal bc then u will be buying a rotor to
Sun Jul 28, 2013 7:35 pm
I'm gonna order pads tomorrow for it might as well get another set
Sun Jul 28, 2013 7:43 pm
Myn is the new style caliper too and my wore completely out at 45 hours and I know I hold myn tight enough
1846 GTB 35 GTR
Sun Jul 28, 2013 8:48 pm
Mine went out in 55 hours and i thought it was just me
Sun Jul 28, 2013 8:54 pm
Sun Jul 28, 2013 8:55 pm
17x54 Extreme Pushed By A Gtr 35 Stage 2 Done ByJamieB Baw!
Nut Up Or Shut Up
Sun Jul 28, 2013 9:03 pm
Mon Jul 29, 2013 4:56 am
True! I guess that ankle bracelet prolly messed things up for him
Mon Jul 29, 2013 6:37 am
Nut Up Or Shut Up
Mon Jul 29, 2013 2:31 pm
Don't figure I have anything to worry ab :lol:
Mon Jul 29, 2013 3:05 pm
I have right at 80 hours on my motor and I don't have much left on my pads. Chris mine or worse than yours. I don't get it. i know of a few people that have 300-400 hours on theres and they've never been changed
1854 Extreme CC 35 GTR
RTR!!!
Mon Jul 29, 2013 4:57 pm
The trick is to bleed the system every now and then!To bleed it correctly(I have found)you need to remove the caliper and rotate so bleeder is at very top so EVERY bit of air can get out!Make sure to place something between pads while doing it.If you get them bleed correct the fukers will not slip ;) Works!
PS-Do not overfill Mastercylinder!That will also cause them to drag!
Mon Jul 29, 2013 5:16 pm
Mon Jul 29, 2013 5:26 pm
Hopefully soon the whole break pad system will be replaced!
Mon Jul 29, 2013 5:34 pm
Mon Jul 29, 2013 5:42 pm
Users browsing this forum: No registered users and 219 guests
