It is currently Thu Apr 09, 2026 12:24 am
Reply to topic  [ 30 posts ]
 Trolling motors
Post Trolling motors
Fishing season is fixing to crank up, and im fixin to buy myself a trolling motor.
So what are yall using??
Minn kota or Motorguide?
24v or 12v?
Foot guide or that tiller thingy?
How many pounds of thrust?
Tue Feb 10, 2009 9:28 pm
Post Re: Trolling motors
boat is an 1860 and trolling motor is a motoguide 70lb thrust 24volt. foot controled
What is THAT????? Aw Hell Ground Check IT!!!!!
Tue Feb 10, 2009 9:52 pm
the first question is what kind/size boat you want to trollerize?
Tue Feb 10, 2009 10:08 pm
Location: In a trailer of common sense, looking out the window at a tornado of stupidity
The first answer to all of your questions is Minn Kota.
All the rest depend on the size of your boat and the thrust power that you want.
The weedless wedge blade on the Minn Kota motors is awesome.
Tue Feb 10, 2009 10:21 pm
I've got a Minn Kota Edge. 12v. 40lb thrust.
Its the bow mount, hand controlled one.It yanks my boat around all day long. I like it. I bought it bc it was cheap (like $250 at Academy) and I didnt need much TM for my boat.
1854 Gatortail CC . 35 GTR Stage 2
Wed Feb 11, 2009 5:13 am
1852
I know cash has an 1848. How fast can you get around with that 40lb?
Wed Feb 11, 2009 7:59 am
I runs the 40lb Minn Kota also on my 1754. All I need.
1754 PD Center Console, 60 Yammy, w jack plate
Wed Feb 11, 2009 8:16 am
Im looking for a 55 Thrust, bow mount, and tiller handle. Damn these things are so expensive.
Wed Feb 11, 2009 8:45 am
minn kota riptide, 12v, 55lbs thrust, tiller handle
Works great all day long on the boat
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Wed Feb 11, 2009 8:48 am
Min Kota is the only way to go!
I got a 55lb foot control 12 volt. It pulls my 1848 at a pretty good pace.
No need for a 24 volt on any duck boat, IMO....
WC Custom 1854
Wed Feb 11, 2009 8:55 am
I rather tiller handle, but it seems like they offer more of them with that 52" shaft. That thing will take up alot of space that is not needed. It looks like like i really should get a saltwater series being in Pecan Island and on the coast fishing.
Wed Feb 11, 2009 9:09 am
i've got a 12v, 40lb minn kota tiller that i bought converted to mount like a standard bow mount. Is plenty for my 17x54.
http://i155.photobucket.com/albums/s295 ... G_0211.jpg
Woody
17x54 Gator-Tail w/ 35HP GTR
Gator-tail/MM exhaust
Center Console...it fixes tiller torque
viewtopic.php?f=4&t=9330
Wed Feb 11, 2009 9:21 am
On my last rig I was running a 24v 71 lb thrust Motorguide. It would scream, prolly a lil to much for a 1754 but it sure was nice to have extra power when we were loaded down for bowfishing. All ill ever own is a 24v system.
Bog Hog......Release the Swamp Monster in your motor!!!!!!!!!!!!
Wed Feb 11, 2009 9:30 am
Wed Feb 11, 2009 10:13 am
got a motorgude 12/24 56 pond thrust foot controlled. I run it on 12 volt most the time sept when its windy I can bump it up to 24. Check out craigs list I bought mine there for a hundred bucks.
27pd pushin a 1748 pd x series
Wed Feb 11, 2009 10:15 am
Shane, why a 24v?
Wed Feb 11, 2009 10:13 pm
Got a 55# MK Powerdrive, 12 volt. Hooked it all up the other day and wanted to see how long the new battery and TM would last. Put it on full power and let her rip at 2 pm and at midnight that sucker was still going. The next day I turned it on and 3 or 4 hours later it finally died. This is outta the water testing btw. But I think a 12 should do the trick with these boat, 24 is a little overkill unless you run that dude non stop.
1754 Excel w/ 45 MB and a 55# MK for back up!
Wed Feb 11, 2009 10:41 pm
Wed Feb 11, 2009 11:12 pm
Ok. Heres another question....
Why Minn Kota over Motorguide?
Thu Feb 12, 2009 7:55 am
cause minn kota looks cooler
Thu Feb 12, 2009 9:10 am
minkota is quieter and smoother than motorguide. 12v 40lb thrust is plenty for a duck boat.
Thu Feb 12, 2009 9:59 am
WC 1848 Bateau w/ 36 PD FPR
Thu Feb 12, 2009 11:00 am
also if you bump into a stump or log minnkota flexes cause of the composite shaft while the motorguide could get bent and stay that way cause its steel
Thu Feb 12, 2009 3:56 pm
I have a 24V 71# thrust MOTORGUIDE. Best trolling motor ive ever bought. Ive owned several min kotas.
WingPhenes™
18x54 ProDrive Powered James Gang Bang
Thu Feb 12, 2009 7:52 pm
Thu Feb 12, 2009 8:29 pm
Thu Feb 12, 2009 11:29 pm
Thu Feb 12, 2009 11:32 pm
The minn kota prop is thicker than the motorguide prop. My father-in-laws is banged up on his bay boat and my prop still looks new even after all the stumps and oyster shells it has hit. And as Capt. said the weedless prop is a lot better than the motorguide. My dad has a great white on his bay boat and it has been repaired to many times to count.
Fri Feb 13, 2009 8:25 am
Im guessing the minnkota's electronics are sealed?
Fri Feb 13, 2009 1:24 pm
Fri Feb 13, 2009 8:43 pm
