It is currently Mon Apr 13, 2026 4:11 am
[ 3 posts ] |
Drake_35GTR
Joined: Tue Jan 27, 2009 9:07 pm Posts: 69 Location: Luling, LA
 Idle
I have the mikuni carb and evt intake that I had installed.... It idles around 900 - 1000 rpm's. When I open the throttle and then let it go, the rpm's come back down to around 1400 then slowly comes down to 1200 rpm's.... The only way it goes back to an idle of 950ish rpm's is if i push the throttle on the carb itself back to close. What can i do?
_________________ 18x46GTB W/ 35GTR..... "Sneaky Stage" sponsered in part by LiL Daddy Customs Rated "Rahhhh"
| Thu Oct 15, 2009 3:38 pm |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
 Re: Idle
More than likely its your throttle cable, First thing I'd check is the way its routed and make sure you don't have to aggresive of a bend.
If not then its either sticking and needs to be lubed (3 in one oil will fix you up) or it has brokin strands and its unraveling inside the sleeve causing friction.
| Thu Oct 15, 2009 3:48 pm |
deadbird8
 Re: Idle
| Thu Oct 15, 2009 10:27 pm |
[ 3 posts ] |
