It is currently Thu Apr 02, 2026 8:46 am
Reply to topic  [ 7 posts ]
 RPMS on a 25 hp kohler
Post RPMS on a 25 hp kohler
I got a 25 hp kohler GD LT. It was running 3200 rpms out of water and 2900 rpms in water. I started play with the linkage and cable and got 4200 rpms out of water. What is a good rpm to run this motor at? Any help would be great thanks
Mon Oct 26, 2009 3:18 am
Post Re: RPMS on a 25 hp kohler
3500 in the water with good prop. 3600 or more with a worn prop. seems like mine is running about 3800 out of the water with a worn prop
Tue Oct 27, 2009 5:28 pm
I agree with the 3500 in the water with a newer prop. If you are getting 3800-3900 in the water, you may need to move up in size on the prop.
Wed Oct 28, 2009 2:55 pm
hell i gots a 23 hp and im turning 3900 in the water and 4300 out the water
BUNDY BUILT SKIFFLESS
cuz der bad ass like dat....
bunnny rabbit customs.
Wed Oct 28, 2009 9:09 pm
I was running 4250 out about 3900 in, turned it down to 4000 out. I should be 3700ish in....someone said 4000 max on here for the Kohlers?
Sun Nov 01, 2009 1:05 pm
I was told today that my 25 gdlt should runnin 4050 out of water and 3850 in the water i dont no what to beleive .
1542 stuck to a 27mini. She gone.
1746 with a modded 35 gdsd
Capt Team total asalt
Sun Nov 01, 2009 8:50 pm
The right question is at what rpms is my motor performing the best?
If I'm running 19mph at 3500rpms and your running 19mph at 4000 rpms, who's motor is going to last longer?
If I'm running 15mph at 3100 rpms, I either have a very large load in the boat, or my prop is too big for my application.
For the 25 kohler and 27 kohler that I had 187 hours experience with, it was right around 3500 with a brand new prop.
Mon Nov 02, 2009 9:58 am
