It is currently Sat Apr 11, 2026 3:31 pm
Reply to topic  [ 8 posts ]
 GD prop
Post GD prop
Kinda confused here. Put a new backh20 prop (9x6) on my GD lt before September teal. ran great with it. Just changed it out Thursday. Had worn it down to 7.5". Put a new GD prop on and it's like the motor can't spin it. Really gives the motor trouble at high rpms in the water. Noticed a lot more cup in the GD prop over the backh2o. Wondering if yall notice a negative difference in performance when you put on a new GD prop.
Sat Dec 21, 2013 5:06 pm
Post Re: GD prop
Old prop vs new prop
Sat Dec 21, 2013 5:33 pm
Post Re: GD prop
That prop looks to be 2 or 3 inches larger than the old one....you sure you got the correct new prop?
Sat Dec 21, 2013 5:58 pm
Post Re: GD prop
It had 9x6 stamped on the hub. Measured it and it 9" across. Only thing that could be wrong is it could be a 9x7 they mis stamped as a 9x6?
Sat Dec 21, 2013 7:39 pm
Post Re: GD prop
No, it is 9x6. Just has a lot of cup when it's new. What size motor?
Sat Dec 21, 2013 8:20 pm
Post Re: GD prop
25 kohler
Sat Dec 21, 2013 8:55 pm
Post Re: GD prop
You should be able to turn that prop. I had a similar experience with a 23. I have a GD prop that is still 9" diameter with a slight wear on cup and I can turn it 3910. I put a new GD 9x6 on thinking it would maybe take 100 rpm but it dropped to 3600 or so at about the same speed. I put my old prop back on because it carries a load better. You don't have that option because your old prop is too far gone. What rpm can you turn the new prop?
Sat Dec 21, 2013 9:09 pm
Post Re: GD prop
No tach on the motor. Haven't put one on it yet. I can tell it's not what it was before though. Really need to get around to installing a tach on the motor.
Sat Dec 21, 2013 9:27 pm
