It is currently Tue Sep 23, 2025 2:21 am
Reply to topic  [ 9 posts ]
 throttle handle mods on gtr35?
Post throttle handle mods on gtr35?
need advice- have very long runs, using gtr35 tiller handle, I find the stock throttle hard to hold for long periods. Can it be safely modified or is there a better aftermarket system?
Wed Dec 02, 2009 10:13 am
MMT Moderator
Post Re: throttle handle mods on gtr35?
Hmmm good question.
I've seen many crawler rigs modified with bicycle gear changers to keep RPM's up while shifting or using clutch...
Why not retrofit a gear selector from a bicycle and tie into your throttle cable. You can set it with a few clicks and then when you want to back off just click it back down to the normal position.
I've seen this done when off roading just not done on the water. Could easily be adapted to work for the GTR or any rig for that matter.
GTB 1860 w/ 2019 GTR40XD-HO
Wed Dec 02, 2009 11:09 am
VELCRO!
Wed Dec 02, 2009 11:26 am
I bought a four-wheeler thumb extension thingy at Wally-world...works pretty good.
I just took a dremel tool and trimmed off that bottom part.
Woody
17x54 Gator-Tail w/ 35HP GTR
Gator-tail/MM exhaust
Center Console...it fixes tiller torque
viewtopic.php?f=4&t=9330
Wed Dec 02, 2009 1:32 pm
Woody,
I notice your power trim buttons on your grip. Do you have that with the new control box or the old?
Either way, what's the deal and the hook up?
Wed Dec 02, 2009 4:32 pm
I loosened mine and turned it down so that when im standing my hand just pulls against the throttle. I left it loose enough so that when it sit i just rotate it to make it comfortable to drive like that.
2060 CC 3/4 Gator-tail 1/4 Brother Breaux Boat /35GTR
Cowboy thought- a thong on a woman is like a barbed wire fence. It protects the property but doesnt obstruct the view.
Wed Dec 02, 2009 4:38 pm
cypress, i had a write-up on the GT forum but it is down...i'll give you a quick look with some pics...i basically bought a trim switch at academy and wired it in to the main trim switch.
Makes it possible to trim and reverse and throttle all at the same time!!
Woody
Thu Dec 03, 2009 9:48 am
Got it. I have the new control box which contains the trim switch. It went out and the goodfellas at gt replaced it but i like your setup. One of the older boats in gt's yard had it as well. I suppose Kyle, et al will eventually redesign the setup to have the trim at your fingertips.
Thanks
Red Stripe...impressive.
Thu Dec 03, 2009 11:37 pm
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Fri Dec 04, 2009 7:54 pm
