It is currently Thu Jun 26, 2025 6:39 pm
Reply to topic  [ 31 posts ]
 Runs Like Crap ....
Post Runs Like Crap ....
I ain't bery smart 'bout all the mechanics operations of these MudMotorMachineThangs ...... but .....
Mines GTR35 gots to runnin' like crap 'bout the last week of the first split .... I mean ..... rruunn .. bumm .. bumm .. rruunn .. bumm .. bumm .. Pop .. bumm .. Pop .. rrunn .. Pop ... and so forth. I changed the fuel filter and it gots me out there two mo times and started that again !!!
I have now fixed the problem and thot I would post it rite here in the Engine Fourm and see ifin' ya'lls can figure what it was !!!!!
One mo hint .... the mo fuel you gave it .. the worse it got ... ideled just fine !!!!
Winner of this said contest gits a Christmas gift !!!! :D
Fri Dec 04, 2009 2:46 pm
MMT Moderator
Post Re: Runs Like Crap ....
Brooks, bad fuel? Did you notice any improvement after swapping fuel filter? They can get clogged up if you got a batch of bad gas. Start simple first.
GTB 1860 w/ 2019 GTR40XD-HO
Fri Dec 04, 2009 2:50 pm
A) Bad fuel
or
B) Beard sucked into air intake
Fri Dec 04, 2009 3:20 pm
FOWLED PLUG OR REV LIMITER GOT WET
Fri Dec 04, 2009 3:40 pm
Little mobetter on the discription of the "Pop" .... it was like a "backfire" type of "Pop"
Fri Dec 04, 2009 3:43 pm
deffinatley sounds like a fuel issue to me. carb pretty clean???
WC 1848 Bateau w/ 36 PD FPR
Fri Dec 04, 2009 3:55 pm
choke linkage came off making the choke flap jiggle around.
BUCK OFAMA
Fri Dec 04, 2009 4:03 pm
Fri Dec 04, 2009 4:11 pm
Chafed wire or bad spark plug?
Fri Dec 04, 2009 4:49 pm
MMT Moderator
You could have one of the wires chafed where the tilt / trim start & forward switches are. I got one of my wires pinched in there and noticed mine had worn down to the bare wire was grounding out causing the motor to miss. You can check those easy buy removing 2 bolts and nuts.
Fri Dec 04, 2009 4:50 pm
fuel tank vent valve was closed. :P :P :P
Fri Dec 04, 2009 6:42 pm
Brooks
1. add seafoam or empty tank out and clean
2. check fuel connections
3. check spark plugs
4. check spark plug wires
5. tear carb apart and clean it.
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Fri Dec 04, 2009 8:04 pm
Fri Dec 04, 2009 9:04 pm
Check Fuel pump, filter getting fuel? Could also be a quick disconnect on the tank if ya have one..............Check plugs......Good Luck
Sat Dec 05, 2009 3:45 am
probably a short between the tiller handle and the driver's seat
Sat Dec 05, 2009 6:34 am
WATER IN FUEL!!!!
Sat Dec 05, 2009 8:17 am
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Sat Dec 05, 2009 8:29 am
cold motor-valves not seating good -burned valves
Sat Dec 05, 2009 9:18 am
Sat Dec 05, 2009 9:19 am
He was trying to bring to many ducks back in and was overloading his boat cause the engine to bog down.
Or rats got in the aircleaner and plugged it up
Sat Dec 05, 2009 9:42 am
bad coil maybe??
Sat Dec 05, 2009 10:05 am
diode shorted or float vavle stuck open
Sat Dec 05, 2009 11:27 am
It got to close to a prodrive and thought it was supposed to be broke all the time.
Just jokin. I dont even know why I thought of that. I dont usaully hate on others.
BUCK OFAMA
Sat Dec 05, 2009 5:24 pm
Fuel line suckin in air or you left da plastic wrapper on da air filter.
Sun Dec 06, 2009 4:15 pm
Vaccum leak somewhere....maybe bad gasket
18x46GTB W/ 35GTR.....
"Sneaky Stage" sponsered in part by LiL Daddy Customs
Rated "Rahhhh"
Sun Dec 06, 2009 10:22 pm
Bad spark plug (fouled) or bad spark plug wire arcing to the cover it is ignition related. :mrgreen:
There is no replacement for displacement!!!!
Mon Dec 07, 2009 7:58 am
Mon Dec 07, 2009 9:03 am
Da most important thin is BROOKS and his beloved GT rig are back in action.
Mon Dec 07, 2009 9:07 am
How many hours on your motor?
Mon Dec 07, 2009 1:40 pm
Mon Dec 07, 2009 1:52 pm
glad to help you may also put a little liquid electric tape on the boots bought at any auto parts stores on it for the time being is also helps on new boots cause it keeps the sunlight off of them which they dryrot from ultra violet light.
Mon Dec 07, 2009 2:30 pm
Users browsing this forum: Google [Bot] and 138 guests
