Simsknives
 Re: 16hp longtail build
Got the right kill switch in and will gps it as soon as I get done with finals. I also need to fab the grab bar and fix a hole in the hull.
| Mon May 06, 2013 6:11 pm |
fowllife08
Joined: Sun Sep 18, 2011 7:25 pm Posts: 3676 Location: down in da flats, LA
Looks good. Ever get a speed?
_________________ 35 GTR chasin a BBC 1848
| Fri Jun 07, 2013 5:47 am |
Simsknives
| Thu Jun 13, 2013 11:54 pm |
Simsknives
| Fri Jun 14, 2013 10:16 pm |
Simsknives
O and thats 18mph not 81mph
| Fri Jun 14, 2013 10:18 pm |
Simsknives
Simsknives
| Sat Jun 15, 2013 9:45 pm |
CapdYa
| Fri Jan 24, 2014 3:01 pm |
Simsknives
do you have the same exact motor as me with the electric start?
| Tue Jan 28, 2014 10:19 am |
Simsknives
I wont be near my motor until this weekend but I ran the cable to the governor arm, which is tied directly to the carb, therefore bypassing the gov. i bought the throttle from my local motorcycle/atv place for like $12 and you can get a bike brake cable from walmart for pretty cheap. i used the mounting bracket for the ignition and a few bolts. I drilled a hole behind the gas on/off valve and used that mounting bracket and a bolt to hold the cable in place. it will make more sense when i post pictures a little later this week.
| Tue Jan 28, 2014 10:24 am |
Simsknives
| Tue Jan 28, 2014 10:27 am |
Simsknives
| Tue Jan 28, 2014 10:28 am |
Simsknives
found the pictures on my phone
Simsknives
aslo had to add a return spring to the arm that you can see in the pictures i think i got it at napa or an auto parts store.
| Tue Jan 28, 2014 10:29 am |
cr244
Joined: Sat Jun 16, 2012 9:43 am Posts: 1504 Location: Watoola, Alabama
thats a nice build. cool set up
| Thu Feb 06, 2014 10:46 am |
milunchbox
what was the cost of this build?
| Sun Feb 09, 2014 11:42 pm |
