quack-quack
 Best semi-v
Im looking at getting a new SD motor mainly so I can sit down on the longer hauls, and want a semi-v due to some of the larger somewhat choppy waters. I will be getting into the backwaters so I wanted to see what the best semi-v option out there is? I cant afford a true mud hull and do a lot of fishing so I want a kind of "everything boat". Looking to keep it 14-16' Duracraft, Grizzly, Lowe, etc they all make one, but who's is the most flat and will ride the best with a SD, or does it not really matter?
Sat Mar 22, 2014 3:58 pm |
Gigafowl
 Re: Best semi-v
Flattest bottom - closest to 18 x 48 - with .125 or at least .100 thickness....
Sat Mar 22, 2014 4:07 pm |
Russ
 Re: Best semi-v
Express jon boat with the v front runs shallow pretty well, and has high enough sides to handle choppy runs. Havent run your other options.
Sat Mar 22, 2014 4:16 pm |
quack-quack
 Re: Best semi-v
I tried looking on the websites but I don't see how you tell which is the flattest?
Sat Mar 22, 2014 4:36 pm |
BERNIE255
Joined: Sun Jun 16, 2013 4:43 pm Posts: 1381 Location: Avoyelles Parish/ Marksville LA
 Re: Best semi-v
my 14' grizzly runs pretty shallow but you need some weight in the front to have it run flat, the only thing i dont like is that it weighs around 430lbs and its only 14'.
Sat Mar 22, 2014 4:39 pm |
quack-quack
 Re: Best semi-v
So if I added Pods, would that help or is that minimal ?
Sat Mar 22, 2014 5:03 pm |
Gigafowl
 Re: Best semi-v
Sat Mar 22, 2014 6:36 pm |
mud slinger 69
Joined: Sun Aug 28, 2011 4:27 pm Posts: 1194 Location: Utah
 Re: Best semi-v
I've got a 15-48 G-3 Mod V with a 23hp surface. It's not bad 21" sides so i can run a liitle chop. It don't run shallow thou. If i'm on plane it will run thou anything in deep water it does seem to be ass heavy. Hope this helps.
_________________ We ant just mormons and polyganists we got rednecks too
Sat Mar 22, 2014 6:44 pm |
quack-quack
 Re: Best semi-v
Sat Mar 22, 2014 6:49 pm |
uppermiss
 Re: Best semi-v
I own a 18V Bayou Xpress with a Sport V and love the boat. It handles good in shallow and deep water with no problem. for a production mud boat it is worth the money. I would stay away from Tracker Grizzly and had nothing but problems sense day 1.
Sat Mar 22, 2014 6:52 pm |
quack-quack
 Re: Best semi-v
I like that Xpress too, I was hoping to keep no more than $6k total though.
Sat Mar 22, 2014 6:56 pm |
mud slinger 69
 Re: Best semi-v
It will run but be very weight sensetive. If you can get a 35 hp and at least a 16-48. If not the 15 and the 23 isn't a bad combo. I like mine just don't like haveing to watch what and who i put in the boat. Running 3 poeple doesn't work. Where you from. Try and set up some test runs.
Sat Mar 22, 2014 6:57 pm |
Gigafowl
 Re: Best semi-v
Every 35 SD on the market is pushing or over 300 lbs....
Ask yourself this - will an extra 2 feet of hull hurt anything ???
It weighs less than 30 lbs more and carries at least an extra 200 lbs of motor and cargo due to the greater displacement and the length is like a long lever to lift that heavy SD....
If you are thinking about how an outboard performs on a given shorter hull - just go put 4 car batteries in the back of the transom and take a spin - that is how much heavier a SD is than an outboard...
Sat Mar 22, 2014 7:01 pm |
Gigafowl
 Re: Best semi-v
Sat Mar 22, 2014 7:07 pm |
quack-quack
 Re: Best semi-v
I hear you about displacement I'm all but I hunt two guys and a dog. I guess I don't want a small boat but don't need a huge boat for just two guys. Plus I want to keep it under $6k used so is that reasonable to expect a 35hp and 18ft boat anyway? All I want is 20mph with a hunt load
Sat Mar 22, 2014 7:08 pm |
Gigafowl
 Re: Best semi-v
I had under 4000 in my first SD rig...
Got used 27 GDSD - 17 42 Weldbilt slick bottom true MM hull with square chines - used trailer...
It is doable if you shop and buy smart...
Sat Mar 22, 2014 7:12 pm |
quack-quack
 Re: Best semi-v
Damn that IS a deal! Well I agree with what your saying and I have 6 months till season so I'll check out the ads more. Might run it by ya if I find something, but thanks for all the help here
Sat Mar 22, 2014 7:16 pm |
Gigafowl
 Re: Best semi-v
Sat Mar 22, 2014 7:22 pm |
Russ
 Re: Best semi-v
Ive driven pretty extensively a 1546 xpress jon with a 27 sd on the back. With two or three plus guns and gear it planes fine and runs well shallow and deep. With your requirement of running in choppy water, I understand wanting the v front. If you're needing shallow water capability as well, go a foot or two longer, but stay light (the 1546 only weighs 315 or so empty). An 1848 would be well suited to a 35 as stated above but isnt necessary for your needs. There's more than one way to skin this cat. With your price range, youll find the right used rig with some searching and patience.
Sat Mar 22, 2014 10:57 pm |
Gigafowl
 Re: Best semi-v
Sun Mar 23, 2014 8:08 am |
quack-quack
 Re: Best semi-v
Alright so im not scared of buying a used motor, but ive delt with issues on a previous motor and had buddies who get a deal and it ends up being work. I was thinking of buying the motor new and the boat used. The difference in cost of a 14-17' is very minimal, i just have to search the threads so im not worried about that, but the cost of a 18hp SD to a 35hp SD just keeps going up.
Are you saying that I could get a 16'-17' used boat, then I could still put on a Dixie 23hp for $3k and that would push 3 guys? If not, what is the minimum hp I would have to go with. a 25hp is $4.5k and a 35hp is $5.5k, yea the step ups arent THAT bad, but it all adds up at the end of the day so im just trying to figure out how to do it the best.
Sun Mar 23, 2014 10:41 am |
brickgw
 Re: Best semi-v
Take it from me...I put a SD on a regular mod v Jon boat 8 months ago. I'm already looking into new hulls and motor mods. My situation was a little different than yours as I already had a hunting boat and no motor...but I'll tell ya you can watch the performance drop with every extra pound you put in the boat. The load carrying ability falls off fast. Too many decoys, an extra person, ice/water in the boat and getting planed out can be a real chore.
Sun Mar 23, 2014 11:06 am |
Gigafowl
 Re: Best semi-v
Sun Mar 23, 2014 11:13 am |
mudslut
Joined: Mon Dec 06, 2010 6:54 pm Posts: 2061 Location: Natchitoches,La
 Re: Best semi-v
I wouldn't go duracraft That's my finger stuck thru the side if the boat
Sent from my iPhone using Smoke Signals
_________________ 1646 Gatortail dragging a stage 1 GTR
Sun Mar 23, 2014 12:26 pm |
quack-quack
 Re: Best semi-v
Sun Mar 23, 2014 12:57 pm |
Russ
 Re: Best semi-v
Sun Mar 23, 2014 1:09 pm |
Westi
Joined: Fri May 29, 2009 2:53 pm Posts: 1006 Location: TEXAS
 Re: Best semi-v
Do a quick search of Dixie before you decide to go that route.
Mon Mar 24, 2014 7:18 am |
Buzz Killington
 Re: Best semi-v
Grizzly Tracker
B. MacDonald
Mon Mar 24, 2014 6:11 pm |
quack-quack
 Re: Best semi-v
Mon Mar 24, 2014 6:39 pm |
BERNIE255
 Re: Best semi-v
Dont know compaired to other boats but my 1448 held a 40hp honda on there well for a day and had no problems, i think that tracker is over exagerating when they use all the bracing in the hull and as a downfall it adds weight. Love the boat tho its a tank
Sent from your blind
Mon Mar 24, 2014 8:29 pm |
WAD SHOOTER
Joined: Sun May 16, 2010 4:30 pm Posts: 667 Location: Clinton, MS
 Re: Best semi-v
If your on a budget check out weldbilt. I think the Crawdad models have a smooth bottom. They have the best prices on aluminum boats hands down. Backwoodslanding.com
_________________ 1542 War Eagle with 25hp GDLT
Mon Mar 24, 2014 8:31 pm |
BERNIE255
 Re: Best semi-v
X2^^
Tue Mar 25, 2014 4:38 am |
quack-quack
 Re: Best semi-v
Yea I do like the Crawdad and have seen a few customer pics, but the only issue is that it doesnt have a front platform. It has a small deck you can put a lightbar on, but nowhere big enough for the dog.
Tue Mar 25, 2014 10:08 am |
Buzz Killington
 Re: Best semi-v
B. MacDonald
Wed Mar 26, 2014 11:33 am |
WhoDat88
Joined: Thu May 23, 2013 4:24 pm Posts: 2912 Location: Thibodaux, La
 Re: Best semi-v
_________________ 1850 Predator Series Stick Steer Option 40HP Gatortail
Wed Mar 26, 2014 1:28 pm |
quack-quack
 Re: Best semi-v
Thanks man. I agree we just don't have any custom builders and I don't know anyone with a true mud setup to even ride in it and understand the true feel. But I'll look into the custom route.. any around NC/SC you know of ?
Wed Mar 26, 2014 1:36 pm |
WhoDat88
 Re: Best semi-v
Wed Mar 26, 2014 1:38 pm |
Russ
 Re: Best semi-v
Contact chad at prodigy. He's in northern georgia, might be able to get him to take you out in one of his before you buy.
Thu Mar 27, 2014 7:20 am |
Gigafowl
 Re: Best semi-v
Thu Mar 27, 2014 7:26 am |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
 Re: Best semi-v
Im in northern Alabama, just shy of Pulaski tn, but still pretty far. And do not get a mod v, been there done that. The price was great but not good enough to make up for loosing performance and shallow ability.
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
Fri Mar 28, 2014 10:44 am |
