It is currently Thu Jun 26, 2025 7:29 pm
[ 5 posts ] |
brglass
 Valve not staying lashed
I have a 35 GTR with decked heads, GT cam, mikuni, and MPE and the exhaust valve on #1 head will not stay lashed. 1 hr of ride time and it will ping and the tappet will slap obnoxiously. I have tightened the nut as tight as i can get it. Any ideas what could be causing it? or suggestions to fix it?
Tue Dec 29, 2009 9:02 am |
coondik
 Re: Valve not staying lashed
check your rocker bolt for tightness cam may be bad
Tue Dec 29, 2009 9:11 am |
brglass
Thanks coondik, i replaced rocker, stud, set screw and nut thinking it was a bad rocker/set screw. Stud has remained tight. GT recommended loctite on the set screw and nut so i guess i'll try that. im hoping its not the cam...
Tue Dec 29, 2009 9:45 am |
coondik
swap that rocker, bolt, adjustment stud, nut, & push rod with the one right next to it. that will help u isolate the problem. if the problem still occurs it may be that lobe on the cam. make shure your settin' @ 1/4 past TDC. may wanna check the valve as well. could be a bent stem or bad guide that's causing it to stick & not fully close!
Tue Dec 29, 2009 11:00 am |
Brinkleydog
Joined: Tue Jan 13, 2009 5:15 pm Posts: 1361 Location: Longview, TX
what did u find out?
_________________ 20 x 54 with 9/16 bottom powered by Twin BLACK CHICKS with FPR
Sun Jan 03, 2010 10:18 am |
[ 5 posts ] |
Users browsing this forum: No registered users and 135 guests |
