It is currently Sun Jul 06, 2025 1:09 am
Reply to topic  [ 80 posts ]  Go to page 1, 2  Next
 Rebuilding the square gator tail trim tonight...
Post Rebuilding the square gator tail trim tonight...
Anybody out there who has any pointers they are welcome. Thanks
Over.
Fri Apr 25, 2014 6:06 pm
Post Re: Rebuilding the square gator tail trim tonight...
Over.
Fri Apr 25, 2014 6:24 pm
Fluid in with the stator and brushes area and the smell off burn fluid is OVERWELMING!! any word?
Over.
Fri Apr 25, 2014 6:50 pm
Looks like you're riding solo on this adventure :lol:
35 GTR - 1754 Extreme
Fri Apr 25, 2014 8:16 pm
I guess so! Thanks guys...rookies:P:P:P
Over.
Fri Apr 25, 2014 8:26 pm
I just did it last weekend...
Clean all of the fluid out of the magnet sleeve. (Or Whatever you want to call it).
I used brake cleaner. Hose the magnet down. Let everything dry.
Replace the Orings on the magnet stem (the tiny ones) those are what prevent the hydraulic fluid from getting to the magnet and the reason these trims suck.
Put it all back together (the correct way) and it should work.
Kool-Aid Brigade
www.southernfowler.com
Fri Apr 25, 2014 8:27 pm
I need help with the check balls got any pics
Over.
Fri Apr 25, 2014 8:59 pm
I didn't take any pics bud.
Kool-Aid Brigade
Fri Apr 25, 2014 9:03 pm
If a take a pic would you remember where they went?
Over.
Fri Apr 25, 2014 9:05 pm
Which ports do these two check balls go in?
Over.
Fri Apr 25, 2014 9:12 pm
the new trim is a POS also... I wonder how hard it is to convert to Mercury trim
THIS SPACE FOR RENT ;-)
Fri Apr 25, 2014 9:15 pm
I didn't even take any of that apart.
Only the magnet sleeve... And it worked after that.
I can't help you there.
Kool-Aid Brigade
Fri Apr 25, 2014 9:16 pm
If I were guessing I would go with the 2 holes on either side of gears, right in the middle of gears. they have fluid passages and check balls check flow one way or other.
Fri Apr 25, 2014 9:30 pm
I hope u get everything figured out cuz I'm have to rebuild mine pretty soon. Is there a schematic of the trim?
Sent from my iPhone using Smoke Signals
1646 Gatortail dragging a stage 1 GTR
Fri Apr 25, 2014 10:28 pm
Fri Apr 25, 2014 10:36 pm
Two of the plungers didn't have O-rings when I disassembled...:?::?::?::?:
Over.
Fri Apr 25, 2014 11:36 pm
Fri Apr 25, 2014 11:39 pm
I will have a full rebuild post when this is done. And going to try a video also. Maybe it will help some Good Lord knows I've learned a lot about this trim unit in the last three hrs.
Over.
Fri Apr 25, 2014 11:53 pm
check ball checkers
Sat Apr 26, 2014 7:58 am
Sat Apr 26, 2014 8:03 am
what are you using for assembly lube?
Sat Apr 26, 2014 8:11 am
hey if you look at your pictures - it shows 1 check ball still in place during tear down
Sat Apr 26, 2014 8:16 am
Sat Apr 26, 2014 9:16 am
I have a couple of pictures if u still need some install info
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Sat Apr 26, 2014 5:01 pm
Sat Apr 26, 2014 6:09 pm
Will post shortly. There on my phone
12 ft 11hp longtail
Merc 225hp TR20
Sat Apr 26, 2014 7:33 pm
12 ft 11hp longtail
Merc 225hp TR20
Sat Apr 26, 2014 7:49 pm
12 ft 11hp longtail
Merc 225hp TR20
12 ft 11hp longtail
Merc 225hp TR20
Sat Apr 26, 2014 7:50 pm
12 ft 11hp longtail
Merc 225hp TR20
Sat Apr 26, 2014 7:52 pm
Last pic is where everything is installed correctly
12 ft 11hp longtail
Merc 225hp TR20
Sat Apr 26, 2014 7:55 pm
check ball checkers :lol:
Sat Apr 26, 2014 9:39 pm
hey Dr. Frankenstein does your creation live? we need another happy ending here
Sun Apr 27, 2014 10:07 am
Holla at bayouboy, He takes shit apart just for fun... :P
Gator tail
Sun Apr 27, 2014 10:15 am
Sun Apr 27, 2014 11:10 am
X2^
Sun Apr 27, 2014 4:57 pm
Check ball installed in the wrong ports. Didn't build pressure....so I opened it back up to see that rear shoulder on two the plungers was sheared off because check balls were in their spot. Going to order parts tom.
Over.
Sun Apr 27, 2014 5:25 pm
Thanks for the pics. baron von
Over.
Sun Apr 27, 2014 5:40 pm
Where are you guys getting these rebuild kits with all the orings and what comes in them?
Wed May 21, 2014 2:37 pm
I couldn't find any at parts houses but gatortail has them.
Wed May 21, 2014 5:34 pm
Users browsing this forum: No registered users and 76 guests
