It is currently Fri Jun 27, 2025 1:55 am
Reply to topic  [ 3 posts ]
 Cold weather cable lube
Post Cold weather cable lube
Normally I lube the throttle cable with WD40(35 GTR stock cable on Mikuni carb). The temp dipped into the low 20's and the throttle cable was extemley stiff. After the hunt I removed throttle cable and flushed it with carb cleaner. It works better in the cold now but it would work better with some lube. I need to get a new cable soon anyway. But what can I use that wont gum up in the cold?
Thu Dec 31, 2009 6:49 am
Post Re: Cold weather cable lube
Quantum Hot Sauce Reel Lube. A little goes a long way.
http://www.cabelas.com/p-0017253117468a.shtml
"Just because I don't respond doesn't make me dumb, just waiting for the retards to quit babbling."
Thu Dec 31, 2009 10:15 am
I use Corrosion X- helps keep the oxidation off it after running in salt too.
Fri Jan 01, 2010 2:57 pm
Users browsing this forum: No registered users and 66 guests
