It is currently Tue Jul 01, 2025 11:34 pm
Reply to topic  [ 135 posts ]  Go to page 1, 2, 3, 4  Next
 GTR 35 arrived today!
Post GTR 35 arrived today!
Took ownership of my new gtr35 with stage 1 and the new lower with handle and 3 blade.
Took it out and best speed I got was 26.8 @3800 ish rpms. Does this sound right? Motor stepped right up on step. Seems like I might be able to trim up a bit more but I am maxed out with the trim. Any suggestions
Also my idle was a little high at 1800ish. Little help adjusting the idle would be appreciated.
Other than that the motor was smooth with very little to no vibration. I am very happy with the motor. Once I get some more tiller time on it I will post a full review.
[color=#80BF00][b]Excel 1860 swv4f4 with GTR35L with stage 1, cam, exhaust, heads
Wed May 21, 2014 5:18 pm
Post Re: GTR 35 arrived today!
Is it on your excel boat?
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Wed May 21, 2014 5:30 pm
Either way, it should be better than that. Check your throttle travel first.
Wed May 21, 2014 5:31 pm
that doesn't seem right man. what does their stage 1 consist of ? Im not sure what the excels are but i know if you put a Gtail on a GT your need to get the transome built up a few inc, MNgunner had to do it. I know from running both Gtail and MB that they don't trim as high as the MB does, not saying thats the problem but it something i noticed.
GatorHide - MB
Wed May 21, 2014 5:45 pm
Also what pin do you have it in?
Wed May 21, 2014 5:48 pm
35 GTR - 1754 Extreme
Wed May 21, 2014 5:53 pm
Stage 1, cam heads, exhaust.
There are 4 pin holes on the new motors. It's in the 2nd hole from the bottom.
Yes it is on my excel without a shim. I mounted the motor and the housing was exactly an 1/2 inch from running level with the bottom of my boat so I left it alone. There is no spray coming up between the housing and the transom when I'm running. I can tell it's about perfect but seems to be just a cunt hair off.
Wed May 21, 2014 6:12 pm
Wed May 21, 2014 6:13 pm
What's your rooster tail look like.
Sent from my HTC One mini using Tapatalk
Wed May 21, 2014 6:14 pm
Does the pin position also matter with the upward travel also or just downward trim?
Wed May 21, 2014 6:15 pm
Move your pin up it will give more up trim
1744 WC Custom
25 GTR
Wed May 21, 2014 6:16 pm
put the pin in the second to last hole and see how it does. you may need to go to the top hole. Being able to trim it up some more should let you get some more rpms. Also did they put that spring on the carb for you?
Wed May 21, 2014 6:17 pm
Pin will change upward travel. Move it up a hole. Also check your out of the water rpms.
Wed May 21, 2014 6:20 pm
Wed May 21, 2014 6:27 pm
Appreciate it fellas. The motor is Damn smooth, even compared to the spot v I used to have.lmao
So moving the pin will give me the upward travel I probably am looking for.
Wed May 21, 2014 6:30 pm
Is this a brand new engine from GT?
Wed May 21, 2014 6:47 pm
Wed May 21, 2014 7:19 pm
I would say give them a call, but I'm sure they will be ringing your phone in the am. Hope you get it worked out.
Wed May 21, 2014 7:30 pm
Pin up, had to do it with my war eagle gtr combo. Helped trimming up to sweet spot, you loose ability to dig, but a quick change pin can be made easily
Samsung S5
Wed May 21, 2014 7:50 pm
Wed May 21, 2014 7:56 pm
Anyone close for you to run the 2 blade?
Wed May 21, 2014 7:58 pm
Wed May 21, 2014 7:59 pm
congratulation on your score man :D
Wed May 21, 2014 8:04 pm
Idle can be adjusted from the front of the motor I brought mine down to 900 in neutral, in gear runs about 700-800 in the water and doesn't stall when I put it in gear. You will see a hole to the left side of your choke, use a long philips screw driver and turn it counter clockwise, will bring your idle down doesn't take much. I would let the engine warm up then start turning it down while its running. I have mine in the second pin on top with a 22 degree transom I'm trimmed all the way up and seems to be ok running 27 mph deep water. Hope that helps, im running 3600 rpm stock motor with the 3 blade same motor as yours. Also I only have the governor spring the it didn't come with the other one. If I can get more speed added the other one I want to know hahaha
Wed May 21, 2014 8:15 pm
Wed May 21, 2014 8:27 pm
The new motors have those holes closed off but I will be opening it back up if it's that easy. Lol[/quote]
mine are open I would just have to put a spring there if it will help hopefully someone chimes in so we can see
Wed May 21, 2014 8:29 pm
Drill a 1/4"hole in the plastic so you can get your screwdriver in there.
Wed May 21, 2014 8:30 pm
Go get you the spring for your governor. Set idle buy it
17x48 extreme stage 2 GTR
Wed May 21, 2014 8:31 pm
Wed May 21, 2014 8:32 pm
Wed May 21, 2014 9:09 pm
Bend the tab to set idel
Wed May 21, 2014 9:12 pm
1754 GTB / 35 GTR
Wed May 21, 2014 9:15 pm
Ok. I will check on getting the spring tomorrow. Thanks again
Wed May 21, 2014 9:16 pm
I know u just got this motor and mods, but when u can, get a mikuni kit. Ur welcome
1754 GTB / 35 GTR
Wed May 21, 2014 9:18 pm
Wed May 21, 2014 10:01 pm
that's why I got the PD EFI kit in my shop waiting for my motor, I will install EFI before I even put oil in it.
Thu May 22, 2014 6:36 am
You should run it first to do a comparison. It will help others make a decision.
Thu May 22, 2014 6:39 am
Thu May 22, 2014 6:52 am
Thu May 22, 2014 7:29 am
Thu May 22, 2014 7:41 am
Users browsing this forum: No registered users and 152 guests
