It is currently Mon Jul 07, 2025 7:05 am
Reply to topic  [ 16 posts ]
 Go Devil ignition system
Post Go Devil ignition system
Is there any way to take off or bypass the Mercury ignition system on the GoDevil motors? I know its on there for "saftey reasons" but alot of times when im riding around in mud i'll kill the motor to just stop and chill for a minute and that thing is a bitch to get back up so i can start it....i figured there had to be a way to bypass it so i could start up while trimed all the way down with out having to pick it up? Or would it be putting the motor and starter in a bind since theres no clutch?
Sun May 25, 2014 2:27 pm
Post Re: Go Devil ignition system
There's a wire on each side of the cylindrical mercury switch. Cut the wires as close to the switch as possible and splice the two ends together. . Did this years ago and haven't looked back since.
Sun May 25, 2014 2:46 pm
X2 one of the best things I ever done too
Sent from my iPhone using
Sun May 25, 2014 2:59 pm
My lab did mine for me. When I rewired it I left those off.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Sun May 25, 2014 3:05 pm
The little black box on the back side of the starter?
And it wont bind up the motor trying to start in mud?
Sun May 25, 2014 3:35 pm
I honestly can't remember where it was located. Mine was black and cylindrical if I remember correctly.
No problem starting when buried in mud.
Sun May 25, 2014 4:45 pm
Should be located on the side cover next to voltage regulator
Sun May 25, 2014 5:16 pm
On my longtail I simply just unplugged the connectors on the killswitch itself.
Sun May 25, 2014 5:25 pm
Sun May 25, 2014 6:14 pm
Using Tapatalk
Sun May 25, 2014 6:56 pm
Mon May 26, 2014 12:19 pm
Using Tapatalk
Mon May 26, 2014 3:16 pm
Is this the black cylider you are talkinf about?
Mon May 26, 2014 3:22 pm
Mon May 26, 2014 3:23 pm
That's it. Or you could just take it out of the holder and zip tie it to your wire cover in picture vertically. Then you don't have to cut any wires at all. If it's vertical the switch will always be closed. Just make sure wires are on the bottom.
Mon May 26, 2014 4:58 pm
Mon May 26, 2014 6:48 pm
Users browsing this forum: No registered users and 101 guests
