It is currently Mon Jun 30, 2025 3:17 pm
Reply to topic  [ 31 posts ]
 2 or 4 bunks
Post 2 or 4 bunks
Well as i am expecting a boat this winter, i am in the process of refinishing a trailer and have some questions. Should i go with 2 or 4 bunk boards? Yes 4 may be a slight bit better but if i go with 2 to save a little on cost will they work effectively as long as they are placed correctly according to the braces positioning in the boat? Was thinking about going with 2 2x8 bunks that are 10ft long and adding hope poly board to the bunks instead of carpet. I would appreciate your thoughts and advice………..Thanks
Soon to be 16.5x48 Instagator pushed by 25 GTR
Wed Jul 23, 2014 8:50 pm
Post Re: 2 or 4 bunks
HDPE POLY BOARDS
Size boat?
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Wed Jul 23, 2014 8:51 pm
16.5x48
Wed Jul 23, 2014 8:56 pm
I've ran 4- 2x4 on edge (4" up 2"wide) on my last 2 trailers and has suited me well.
Sent from my beeper
Wed Jul 23, 2014 9:17 pm
You'll be fine either way.
Just don't want to cause hooks or issues in the bottom and wann make sure it will be stable
Wed Jul 23, 2014 9:39 pm
Just make sure your boards run the full length of the boat. It sounds like you know enough to setup your trailer.
Wed Jul 23, 2014 10:38 pm
2 would work but why not go with 4? We are talking and $25 worth of lumber to make sure you have plenty of surface for the boat to sit on.
Thu Jul 24, 2014 6:24 am
I put 3 2x6's flat, been that way 5 years with no problems.
Staff Sergeant of Marines...1990-2005
Proud Dad of 3...1993, 1994, 2005
1644 Gator Trax...MB 27 mini (sold)
1654 prodrive....36 prodrive for & efi
Thu Jul 24, 2014 6:29 am
Last 2 trailers I have put 4 2x6's for a 48" wide boat.
Thu Jul 24, 2014 9:14 am
3 2x6's on mine as well
17.5x48 CC w/ PD 36 Gen 3 EFI E2
"They cant put anything on the internet that isn't true."
"Where'd you hear that?"
"The internet"
Thu Jul 24, 2014 10:05 am
might look into 3 the lumber isn't the expensive part I'm on a budget and the brackets are gonna run me $100
Thu Jul 24, 2014 11:17 am
KC, I have a trailer waiting on Jay to finish up. I think I'm just gonna stick with the 2 bunks and just make sure they extend all the way back to the transom.
Thu Jul 24, 2014 12:46 pm
yea I'm thinking 10 ft long and 2 2x8 bunks will work perfect, i thought he was done w ur boat?
Thu Jul 24, 2014 1:46 pm
1856 Phowler commercial hull with extra flotation so I can run shallower. Pushed by a stock Prodrive until my wife gives me more money
Thu Jul 24, 2014 2:01 pm
The reason I'm running brackets is because according to my boat builder i will need to be able to adjust them to fit his boat as he does a little something different to his boats and i will need it adjustable
Thu Jul 24, 2014 4:03 pm
Thu Jul 24, 2014 7:14 pm
you were right on waiting I'm assuming his proposed date of december for me may be later than that
Fri Jul 25, 2014 5:29 am
how much could 2 more 2x4's with some poly on em c0st?
1854 Prodigy DPE Level 3 HDR
Fri Jul 25, 2014 6:10 am
Fri Jul 25, 2014 6:12 am
If you're going to have to do something specific for the boat, I'd just wait till you get it and then build a couple angle iron brackets to fit it and then slap your boards on. Much easier way to go if you wanna keep the hundo in your pocket. I don't see why 2 or 3 flat 2x6's wouldn't work in the middle though, I thought the only thing different on one of Jays hulls was the chine, the trailer bunks shouldn't interfere with that I wouldn't think.
-Custom pool noodle
-stage 4 water wings
Fri Jul 25, 2014 6:57 am
4
Fri Jul 25, 2014 7:06 am
Jay Dore
Fri Jul 25, 2014 11:27 am
[quote="markoutdoorz"]I put 3 2x6's flat, been that way 5 years with no problems.[/quotethis ^^^^]
Fri Jul 25, 2014 12:29 pm
true I wouldn't be opposed to 3 or even four, but i can always add more if needed. probably just gonna roll with 2 wider boards and if i need to change when i get it, then ill modify
Fri Jul 25, 2014 1:50 pm
Just spend 10$ more now and don't ever fuk with it again.
Fri Jul 25, 2014 1:55 pm
Sat Jul 26, 2014 10:35 am
I have 3 on my trailer but my boat is only 38" bottom with 5 braces. So I have a 12' 2x6 down the middle one and 8' 2x4s on the outside most braces. Just put the pvc trim from home depot or lowes on top with the fake wood grain facing up and countersink the holes. Works great for me.
Sat Jul 26, 2014 6:22 pm
Sun Jul 27, 2014 8:16 am
Sun Jul 27, 2014 4:20 pm
Users browsing this forum: Google [Bot] and 471 guests
