It is currently Sun Dec 21, 2025 5:43 pm
Reply to topic  [ 16 posts ]
 DIY Styx River Nat Gear camo
Post DIY Styx River Nat Gear camo
Crisis defines character
Sat Aug 09, 2014 6:43 pm
Post Re: DIY Styx River Nat Gear camo
Fine job!!
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Sat Aug 09, 2014 6:47 pm
Damn fine job! How long did it take?
Sat Aug 09, 2014 6:59 pm
Sat Aug 09, 2014 7:05 pm
I can't believe how good you got it around the floor braces and the half pipes down the sides. And you camoed everything. It really shows that you took a lot of time with it, looks great. How did you get the stencils to bend around everything so well?
Sat Aug 09, 2014 7:20 pm
Thanks for the compliments. I turned the hull upside down to do the outside and the stencils lay flatter, using a coat hanger around the v crimp helped as well. In the end I just cut up a stencil and used in the tight areas and bracing. Patience is key, and keeping the stencils clean also leads to better results.
Sat Aug 09, 2014 7:28 pm
What brand/color is your base coat?
Sat Aug 09, 2014 8:24 pm
Sat Aug 09, 2014 8:36 pm
Thanks. It came out really good.
Sun Aug 10, 2014 4:30 am
Boat looks awesome. Ive always liked the lines on brothers hulls. Post up a report when it's finished.
WC Custom 1854
Sun Aug 10, 2014 9:55 am
Thanks FT, have a GTR on order and still collecting info on the transom angle issue. This one is at 15 degrees and not 20 degrees like GT specs on their boats. From what I hear there are viable options - per Brother he never has had a hull he has built not run well with a GTR on this transom angle (I absolutely believe this), shimming to get a deeper bite if I need to dig out. I expect it to run and perform but want to ensure it will be the best setup on whether I shim or not. I just want to get back on the water.
Sun Aug 10, 2014 10:16 am
Love it. The boat and paint look great.
1854 Brother Breaux and Boss 40XP and 90hp outboard.
Mon Aug 11, 2014 3:13 pm
Very Nice!!!
http://www.gatorglide.com/
gatorheads@comcast.net
Mon Aug 11, 2014 3:43 pm
Nice. I sprayed Natural base on mine, but never finished
1648 old style bass tracker with a...........................
50 Nissian on a 17' Lakesport.
Mon Aug 11, 2014 9:08 pm
That boat is beautiful
1850 Uncle J
Delta Performance level 4 GTR
Mon Aug 11, 2014 9:28 pm
I appreciate the comments guys.
Mon Aug 11, 2014 9:37 pm
