It is currently Mon Sep 22, 2025 1:15 pm
Reply to topic  [ 11 posts ]
 PD Lower unit removal/motor removal
Post PD Lower unit removal/motor removal
I've replaced a lower unit on my old 27 without a problem about 2 years ago. Now I'm trying to do it on a 36, which should be the same but a bit heavier. I've tried everything and I have to be missing something.
Removed the four bolts/spacers and the motor aint budging.
Wed Jan 20, 2010 7:24 pm
Post Re: PD Lower unit removal/motor removal
shaft is probly stuck to the coupling under the clutch. spray sum lube in there and let it soak a while, then use a come-a-long/ chain hoist to lift off engine.
it will come off. :)
Wed Jan 20, 2010 8:07 pm
^^^^^^X2... U might have to stick a pry bar up under the spline coupler and help it out while ur lifting on the engine to get it to budge.
Wed Jan 20, 2010 9:08 pm
I've tried everything I can think of and nothing.
step 1: remove the four plate spacers bolts and the clutch bolts....as per prodrive's directions.
What are the clutch bolts? Sorry for my unintelligent question.
Wed Jan 20, 2010 9:50 pm
You dont need to remove the clutch bolts unless your removing the clutch. Like others have said. The shaft is stuck in the coupler, the round black piece connected to the clutch. The shaft just slides up into it. Spray some penetrating oil in the top of the coupler and let it set awhile.
18x48 Charles Leonard / 36PD
Wed Jan 20, 2010 10:51 pm
UM.........it kinda sound like you have taken the wrong 4 bolts out.....been there done that!!!! :mrgreen:
Make sure you are removing the correct spacers. If you have taken the motor bolts out put them back in and remove the bolts from the mounting plate to the lower unit. Should come off if the lower unit was lubed properly. If not i just pulled like hell with my forklift and taped on the lowerunit with a hammer and the pusted right off.
For what its worth if you are having to replace the lowerunit only not the tilt or anythign like that make sure you have an extra hand. It is kinda sticky n tricky the first time......kinda like all first times :lol: :lol:
later
Thu Jan 21, 2010 8:49 am
All you noobs need to let folks know where you call home. Might be someone close that can lend a hand.
Thu Jan 21, 2010 7:43 pm
ETD88 09/28/09-05/14/2010...
Fri Jan 22, 2010 1:24 pm
Got it off, just stuck on there good like yall said. Took a half can of pb and 4 guys pryin on it.
Thanks for the help!
Fri Jan 22, 2010 7:30 pm
you da man.....
its always nice to have some big friends n times like that.
reminds me of a time when o willet was tryin like hell to get his prop to budge.....i put my big gut on it and bam that ho was off.....
let us know how the new lu turns out.
Fri Jan 22, 2010 8:01 pm
yep, sometimes ya just gotta have some more azz :D :D
Mon Jan 25, 2010 2:17 pm
