It is currently Sat Jun 28, 2025 5:59 pm
[ 7 posts ] |
dcmab
 35 mud buddy fuel issues
Hello guys. Been awhile. Got a 35 with mikuni and exhaust. It wasn't getting enough fuel and back firin through the carb the other morning hunting. Figured it was my fuel line and by passed all of it and had a foot of line straight to the pump from the tank. Fuel filter won't stayed full and won't run unless I feed it starting fluid. Sounds like a fuel pump to me. 180 hours on it stock pump.
Thu Jan 15, 2015 4:38 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
 Re: 35 mud buddy fuel issues
Why would it backfire if it couldn't get fuel? Had it been running fine?
Thu Jan 15, 2015 4:43 pm |
dcmab
Ran fine about 6 hours before. Backfiring through the intake is a indication of the motor running lean
Thu Jan 15, 2015 6:21 pm |
270Handiman
Running lean is different than starving for fuel. Will it run if you keep pumping the bulb?
Thu Jan 15, 2015 6:25 pm |
dcmab
doesn't have one. When I ran it Wednesday morning I could limp it along and actually got it to run to the spot. but It would be running terribly and bogging and backfiring through the intake. like its not getting enough fuel.
Thu Jan 15, 2015 9:57 pm |
baron von
Joined: Tue Jan 21, 2014 2:52 pm Posts: 2806 Location: Minnesota
what do your sparkplugs look like - can you pull them and post pick?
_________________ that's going itch when it dries
Fri Jan 16, 2015 9:35 am |
DENNYEDWARDS
Joined: Sun Aug 09, 2009 12:50 pm Posts: 574 Location: Muscatine, Iowa
Check for water in fuel.
Fri Jan 16, 2015 11:37 am |
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 260 guests |
