It is currently Wed Jul 09, 2025 12:58 pm
Reply to topic  [ 1 post ]
 Help on gear and prop selection.
Post Help on gear and prop selection.
So Im almost don't with my surface drive build. Its come down to ordering the gears and prop. Im running a Predator 420 on a tracker 1236. My usual load is 2 people guns dekes and a blind. I was going to go with chain and sprockets to tune in my sprocket size then find something comparable from Gates and use a 3/4 or 1 inch belt. My question is what top and bottom pulleys and what prop should I go with. This is my first surface drive build and I was to get it as close as I can with this first order.
Ive narrowed it down to a few sprockets to give me a good range of gear ratios.
I was thinking of buying 16T, 18T, 27T, and 28T sprockets. this should give me ratios from 1.75:1 with the 16T/28T combo all the way down to 1.33:1 with the 18T/24T combo. I could even get close to 1:1 with the 16T/18T if I wanted to. I am hoping I am on the right track.. All these sprockets are pretty inexpensive so I don't mind buying a few and tweaking to get it right.
My Main questions are 1. does the sprocket setup/selection look good or should I go with a different route and 2. what size/style prop should I go with. I want to turn a bigger prop to take advantage of the ability to gear down the motor but I just don't know what size to buy and at 150 bucks a pop I don't want to shoot in the dark and hope I got the right one.
Sorry for the long story I just wanted to be sure I got all the info out there.. Thanks in advance for the help!
Thu Jan 22, 2015 8:32 am
Users browsing this forum: No registered users and 55 guests
