It is currently Sat Dec 20, 2025 10:33 am
Reply to topic  [ 197 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 GTR 37 EFI on 18x60 Go Devil **re-powered**
Post Re: GTR 37 EFI on 18x60 Go Devil **re-powered**
If it's being tough on left turns, I would imagine you would move the motor to starboard.
Thu Mar 12, 2015 10:12 am
Thu Mar 12, 2015 10:27 am
yes and if it works you can always just silicone the holes shut where old bolts went
Thu Mar 12, 2015 10:31 am
Thank you very much. Im going to have to wait till i get home to do it. I may just pull the bolts out and slide it all the way over on the transom then have my neighbor weld the holes up the slide it back to where it needs to be
Thu Mar 12, 2015 10:50 am
I have a big/heavy 18x60 also and I think I got best results moving it the other way QS - I'll recheck it when I get out to the barn tonight
Thu Mar 12, 2015 10:56 am
Thu Mar 12, 2015 10:57 am
The holes should be well above the waterline. No need to weld them, silicone will be fine.
Thu Mar 12, 2015 11:13 am
Thu Mar 12, 2015 11:20 am
Thu Mar 12, 2015 11:28 am
Fighting to turn left? Im confused, move the motor left or right..? Its torqueing towards me, so its hard to make a left turn in the boat.
Thu Mar 12, 2015 11:35 am
^^^^That is what mine is doing. Which way to move motor?
Thu Mar 12, 2015 11:45 am
Thu Mar 12, 2015 11:56 am
Thu Mar 12, 2015 12:28 pm
Fuck all the left and rights if the motor pushing to you move the motor away from you on the transom, as I mentioned before
Thu Mar 12, 2015 12:43 pm
Thu Mar 12, 2015 12:44 pm
Thu Mar 12, 2015 12:45 pm
Lol okay im just trying to make sure i only want to do this once
Thu Mar 12, 2015 2:08 pm
Put a 36 on that skeg and pull...
18X44 Geaux Custon Powered By MB 4500 BD
Thu Mar 12, 2015 3:02 pm
Lol^
I moved down 1 pin hole and that helped alot. Lost alittle speed abd even trimed all the way up it still wasn't throwing a rooster tail
Thu Mar 12, 2015 3:51 pm
Lost about 300 RPMS and 2-3mph on top end
Thu Mar 12, 2015 4:12 pm
yep, sounds like you ran out of up-trim.
Thu Mar 12, 2015 4:17 pm
I like that the torque is gone..i dont like loosening speed..
Thu Mar 12, 2015 4:34 pm
Eat - Sleep - Hunt ! ! !
Thu Mar 12, 2015 5:38 pm
Thu Mar 12, 2015 6:15 pm
I figured - I thought he meant like a 36 quart Yeti - ;)
https://www.youtube.com/watch?v=IuGAggeUWb0
Thu Mar 12, 2015 6:28 pm
How many times are you gonna post that video on here? Lol it wasn't even mine it was a friend of mines yeti..oh and btw is .22lr proof too
On a side not i just got done hanging limb lines and reverse is absolutely amazing no idea what i was missing
Thu Mar 12, 2015 6:36 pm
Thu Mar 12, 2015 6:41 pm
It might be idk if he put it on there or not. The dog chewed the lid up and ruined it so we decided we'd see exactly what all they'd hold up to
Thu Mar 12, 2015 6:45 pm
40HP Gatortail
Thu Mar 12, 2015 6:48 pm
40HP Gatortail
Thu Mar 12, 2015 6:53 pm
Thu Mar 12, 2015 6:56 pm
I always thought it was like Beetlejuice... he just turned up if you say his name too many times.
Thu Mar 12, 2015 6:57 pm
viewtopic.php?f=5&t=56496&p=769483&hilit=skeg+wedge#p769483
Your not the first to have tiller torque issues with the new improved cast outdrive....
Get that addon wedge....
Thu Mar 12, 2015 7:02 pm
If his is anything like mine, it's not when running in a straight line. Mine will hold a straight line just fine and not beat me up at all. Turning to the right is easy as well. Turning to the left? Gotta put a foot up on the opposite side and yank that tiller to come around. To get it to straighten back out you have to grit and bear down and shoulder press the tiller away from you (maybe a little dramatic, but left turns are very difficult).
Thu Mar 12, 2015 7:07 pm
Since you cant bend cast, would it make any difference if i got someone to put a bead of weld or two to add onto the bend in the skeg?
Thu Mar 12, 2015 7:15 pm
Does your skeg not have a flare on the end on the left side?
Thu Mar 12, 2015 7:17 pm
Yeah it does. I just thought maybe if it had alittle more to it tjat it might help force the motor the other way.
Thu Mar 12, 2015 7:28 pm
It has been mentioned by many new 2015 GTR buyers....
viewtopic.php?f=2&t=54296&p=739582&hilit=wedge+tiller#p739582
viewtopic.php?f=5&t=54312&p=738984&hilit=gtr+wedge#p738984
Saw a bolt on wedge somewhere....
Thu Mar 12, 2015 7:39 pm
