It is currently Mon Mar 30, 2026 1:02 pm
Reply to topic  [ 11 posts ]
 9hp performance
Post 9hp performance
Is there any performance parts for the 9hp honda for am i just stuck with what i got lol.
A lanyard and a few empty shells dont make you a duck hunter- Duck Commander
Mon Feb 15, 2010 1:19 pm
Post Re: 9hp performance
Also my shaft has a very slight bend in it :lol: (go devil shaft). Will this affect anything?
Mon Feb 15, 2010 2:47 pm
Its gunna vibrate that a Biotch!
ETD88 09/28/09-05/14/2010...
Mon Feb 15, 2010 2:50 pm
Damn would it be wise to try and heat it and bend it out straight or would that just weaking that spot?
Mon Feb 15, 2010 3:06 pm
Best would be to call GD and get a new shaft. I dont believe they are very expensive. but you MAY be able to straighten it some.
Mon Feb 15, 2010 3:22 pm
36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
Mon Feb 15, 2010 3:38 pm
Thanks ya its not much of a bend at all really. The prop turns just fine.
Mon Feb 15, 2010 6:38 pm
are you 100% sure it's bent? i may be wrong but i see it hard for a GD shaft to bend, cause of the bushings they keep in the shaft tubes. definitely check it if you have any doubt. those are precision parts and everything will have to be replaced if not dealt with.
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Tue Feb 16, 2010 7:34 pm
Yes its a very slight bend in it. I was given the frame by a friend and this is one of the first models GD came out with is what he told me.
Tue Feb 16, 2010 7:40 pm
DAYYYYYUUUUMMMM Boy! If thats the case you settin on a goldmine!!! :lol: :lol: :lol:
Jest a kiddin woth ya.. If ya havein it turn the prop fine and shes not a vibratin ya plum off the boat, I say roll with it :D :x :P
1436 Alumiweld with a 7.5 Longtail
Backwater Retrievers
Home of: Backwater's Settin On Go "Bella"
RNT CALLS
Wed Feb 17, 2010 10:37 am
lol. I should be gettin my motor at the end of this week. I can rotate it by hand just fine. Im just working on a very low college student budget lol.
Wed Feb 17, 2010 1:41 pm
