It is currently Mon Jul 07, 2025 4:45 am
Reply to topic  [ 29 posts ]
 seasoning black iron. ever tried this?
Post seasoning black iron. ever tried this?
Seasoning black iron with bacon?
....why not?
When I cleaned my pot last night, I used dawn.
Yea I know never use soap but I wanted a deep clean.
but think ima Cook up bacon in it tonight to get it back right an start re seasoning it.
would bacon leave salt in it with a result in rust?
Let's Roll
Mon Apr 06, 2015 7:10 am
Post Re: seasoning black iron. ever tried this?
I have seasoned with bacon and not had a problem. I sometimes wash mine well too even though I do not to scrub it, ever!
Mon Apr 06, 2015 7:15 am
Cook some bacon in it and then clean it with stainless steel wool.
You don't get it quite hot enough just cooking bacon. Need to get it pretty got to season it well.
We always put oil in it and throw it in the oven on about 450 for a hour or so. Or throw it in a fire.
Sent from my beeper
Mon Apr 06, 2015 7:51 am
Bacon will work but its not the best. I use crisco it Pam on a couple different.heat stages in the oven. A quick way is to put some oil in it and cook a big pan of cornbread.
Mon Apr 06, 2015 9:19 am
Once clean as in Gray metal left. I coat my pots with shortening or Lard. I then put the pot upside down on my grill and let it get about 500* and let it get HOT. It will smoke like a train, but it is leaving the carbon on the pot that will season it. If you want it blacker do it again.
When you clean the pot use clean water only, dry pot completely and then coat it lightly with Shortening for storage.
Mon Apr 06, 2015 9:32 am
This is good advice. I did mine in the oven this way, but outside would be better.
My gripe is that my season wasn't uniform at first. I had bald spots in the pan etc. I think it's because the new lodge pans aren't as nice as the old stuff. Through a bunch of uses the season in my pan evened out a lot.
Mon Apr 06, 2015 10:09 am
Mon Apr 06, 2015 10:18 am
Mon Apr 06, 2015 3:41 pm
I tried. My pan kept growing mold. So I threw it out in the garage
I've heard they're better if you take it and have the inside smoothed out and polished at a machine shop.
Mon Apr 06, 2015 4:20 pm
We put pot coated with lard on an open wood fire and burn the hell out of it. Use cheap mop to keep coating it with oil each time the prior coat burns out.
Mon Apr 06, 2015 5:14 pm
Just wash with hot water--NO soap. Dry with paper towel. Heat back up on stove to evaporate all water and wipe down with vegetable oil while still warm.
If you have to re-season then do as others have said with pan upsidedown in oven.
Mon Apr 06, 2015 6:25 pm
Mon Apr 06, 2015 6:43 pm
I use a crawfish burner and a BBQ mop with lard. Get it super hot and mop the lard all over it. Will smoke like crazy then let it cool down. It should be black and shiny when you finish
Mon Apr 06, 2015 7:15 pm
I told you the quick way now I'll tell you the good way since I have time to type.
Heat the oven to 225* and put the skillet in for 15 minutes.
Pull the pan out and rub a liberal amount of lard or oil in it and wipe I back out. While your doing this step heat the oven to 325.
Put the skillet back in upside down for 15 minutes.
When you're at the 15 minute mark turn turn the oven to 425, pull the pan out and wipe out again. Don't add any more lard.
Put the skillet back in upside down foe 2 hours then turn the oven off and let it cool natural. You can do this up to 4-5 times and it will be a great season that's hard to get off.
Also you can strip your old seasoning off with heavy duty oven cleaner or soaking it in lye. I do several pieces of iron this way a week and having had a problem yet.
Mon Apr 06, 2015 7:19 pm
Mon Apr 06, 2015 7:45 pm
Damn guys, this is the most positive feed back I ever got on this site! Lol I need to stay on the cooking forum more often!
I appreciate it, I keep haveing pots i don't use often either mold up or get rance.... is this due to not being seasoned right? R just neglectation?
Let's Roll
Mon Apr 06, 2015 7:57 pm
I don't cook in some for 6 months and never had mold.
Do you heat them up after use?
Mon Apr 06, 2015 8:20 pm
Just on stove top to dry out n add oil to wipe down..
That's y I soaped 1 down to see if it would store better...
Let's Roll
Mon Apr 06, 2015 9:03 pm
After ypu wash pot put it on burner until completely dry, then while still hot pour couple table spoons of oil in it and spread with paper towel over entire inner surface. Mine sit for months after hunting season and never get mold
Mon Apr 06, 2015 9:29 pm
Tue Apr 07, 2015 6:38 am
You don't want to leave too thick of a coat on it for storage. Just enough to give a deep shine. I used lard to originally season the pan but now I just use olive oil after drying it. Just put a small amount (size of a quarter) and rub the whole pot down with a paper towel. Throw it back on the burner for a few minutes then shut it off and let it cool. No issues with mold or smell.
Tue Apr 07, 2015 7:13 am
Tue Apr 07, 2015 7:18 am
Try seasoning the same way BayouBuster stated, but with falxseed oil. It comes out slicker than cat shit and makes a hard finish. When you dry your pot on the stove after cleaning, make sure to not put the lid on too tight, or don't forget about it if you do..... I split my favorite pot right down the center doing that.
Tue Apr 07, 2015 7:35 am
Tue Apr 07, 2015 9:51 am
Tue Apr 07, 2015 10:06 am
Tue Apr 07, 2015 9:44 pm
Wed Apr 08, 2015 7:47 am
Thu Apr 09, 2015 6:40 am
I was at Dick's Sporting Goods at the end of this past duck season. First time is ever been to one but I had received a gift card so I went and looked around. I found two large 14" Lodge skillets for $20 each! I was tickled to death! These are the first NEW pieces of cast iron cookware that I've bought. I seasoned them on the grill and they've been great.
Thu Apr 09, 2015 11:47 am
Users browsing this forum: No registered users and 16 guests
