It is currently Sat Apr 04, 2026 8:27 am
Reply to topic  [ 9 posts ]
 Wix filter p/n
Post Wix filter p/n
New rig is ready for her first oil change, can't seem to find the Wix number for the filter I need, I've searched. I'm assuming it's the same as any other big block Vanguard. This is for my 37 EFI
-Custom pool noodle
-stage 4 water wings
Mon Apr 13, 2015 7:15 am
Post Re: Wix filter p/n
Mon Apr 13, 2015 7:20 am
I use #51438.
Mon Apr 13, 2015 7:40 am
viewtopic.php?f=3&t=46207
Here"s a thread with the numbers for several brands of filters
Mon Apr 13, 2015 7:53 am
-Custom pool noodle
Mon Apr 13, 2015 10:02 am
Turns out that a Napa 1056 filter is made by WIX (says on the box) and is a couple bucks cheaper. I picked up a case of them this morning and a case of oil. Should be good to go for a while ;) I plan on changing it every 20hrs.
-Custom pool noodle
Thu Apr 16, 2015 8:03 am
57035 Wix OEM replacement for B&S 842921 Filter
51348 Has a Larger capacity and better filtering, though the tradeoff is a higher bypass pressure. (sort of)
Part Number: 57035
UPC Number: 765809570351
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Enhanced Cellulose
Height: 2.305(59)*
Outer Diameter Top: 2.923(74)*
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=20/41
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 32
Part Number: 51348
UPC Number: 765809513488
Service: Lube
Type:
Height: 3.404(86)*
Outer Diameter Top: 2.921(74)*
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Beta Ratio: 2/20=6/20
Nominal Micron Rating: 21
Capacity: 7
Sun Feb 19, 2017 10:28 pm
I've gone to the 51348 since this post. All those napa filters get used on the lawn mower at the rate of one a year :lol:
-Custom pool noodle
Sun Feb 19, 2017 11:32 pm
I use briggs, But I do get them at a good rate. For resell that is LOL
Mon Feb 20, 2017 7:09 am
