It is currently Tue Jun 17, 2025 9:37 pm
Prodigy 1954 w/GTR 35 w/Heads, Cam, Exhaust, Ecotron EFI
mikecatt13
Joined: Mon Dec 15, 2014 10:40 pm Posts: 370 Location: SE Michigan
MM Brand: Gatortail GTR Horsepower: 35 Boat Brand: Prodigy Boat Size: 1954 Boat Layout: V-Rake, Extended Deck, Fishtail Transom w/2 half boxes, cat walk trays, cat walks. See comments for all the options!
Speeds | Shallow Water: N/A so far
Speeds | Deep Water: 29.4-29.6 Steady Total Boat Load With Gear Etc: Empty (without poling platform), 260lb driver, 10 gallons of fuel, spud poles, GPS, all the permanent options still in (cat walks w/ trays, half boxes, wet sounds, Seat bases, "Evolve" deck track system, reverse lights) Conditions Tested In: Light breeze/chop
Speeds | Deep Water: 27.6-27.8 Steady Total Boat Load With Gear Etc: Empty (without poling platform), 260lb driver, 10 gallons of fuel, spud poles, GPS, all the permanent options still in (cat walks w/ trays, half boxes, wet sounds, Seat bases, "Evolve" deck track system, reverse lights), Ulterra trolling motor and 2 batteries UP FRONT (made a big difference with that weight being up front, going to test with batteries in rear and probably end up moving them there) Conditions Tested In: Light breeze/chop
Speeds | Deep Water: 24.7 Steady
Total Boat Load With Gear Etc: Empty (without poling platform), 260lb driver, 275 lb passenger, 180 lb passenger, 85 lb dog, 10 gallons of fuel, spud poles, GPS, all the permanent options still in (cat walks w/ trays, half boxes, wet sounds, Seat bases, "Evolve" deck track system, reverse lights), cooler with water and snacks, Safety gear and tools (spud pole winch, 4 life vest, anchor with chain and rope, socket set, hand tools), 2 dozen teal decoys, another 70 lb decoy bag (motion decoys (2 mojo teal, hidgon pulsator goose 20 some lbs, mojo feeder) and honker floaters), raffia grass netting which is probably 35 lbs dry.
Hammer prop @ about 3900 rpm
Both Speeds were achieved at around 4680-4700 RPM with Bid Blade prop
Will update with shallow water speeds as well as speeds with different loads (and if I move the batteries)
Comments:
EFI: Motor idles smoothly and consistently at 800 RPM, throttle response is great, and has plenty of power (as far as a 35 HP SD anyway) to get on step and push the boat. Haven't owned a carb version of this motor, but the EFI seems pretty good on fuel. I will say that the air filter system takes a little modification, I had it fall off just because the plastic is pretty rigid so it's hard to clamp on solid. I just ran a couple stainless screws (length carefully selected and done off motor so no plastic entered intake of course) under the hose clamp and it will never go anywhere. Less than $1 and 10 min, permanent fix.
Here are all the details on the build: -Prodigy 1954 all 1/8", Prodigy Grass Camo -GTR 35 with Hoyts head work, cam, Exhaust and EcoTrons EFI -21" Sides -Removable Grab bar -Recessed Floor Bracing -3 Seat Bases on Floor, 1 on Extended Deck -Prodigy Fish Tail Deck/Transom w/2 half boxes and removable center deck section -V-Rake w/ice breaker -Extended Deck w/hatch -Trolling Motor Bracket for Minn Kota Ulterra w/I Pilot Link -Removable light bar with 12" Middle and 6" on each side, all Seelite WAV -12 Gallon Permanent Tank w/gauge -8 Foot Spud Pole Kit w/Holde -Diamond Cut Turf on All Surfaces -8" Cat Walks w/trays (1 bent, 1 vertical) -Dual 1500 GPH Bilges w/JR Pump Station -Shark Eyes -Green LED Interior Lights -Spud Pole Winch -Humminbird 899 DI SI on RAM Mount -Wet Sounds 10 Speaker Stealth -12 Volt Plug and Dual USB Plug -Rear Poling Platform w/Seat Base -Prodigy Blind Kit (Not Pictured) -Sliding Transducer Bracket -"Evolve" Track system with 2 Moveable deck sections (see pictures for different setups) -Bow Fishing Platform w/8 50 Watt Seelites Halo color on a bigfoot switch -4 Welded-in Cupholders
I think that covers it, haha. Wanted a very modular and versatile boat, Prodigy delivered on my dream rig! Everything truly met or, most commonly, exceeded my expectations. The craftsmanship and fit and finish is second to none in my opinion.
In all fairness, I tried the best I could to nit-pick the boat and try and find anything that was "wrong" with it. I am a very particular person and am 100% happy with the boat. But, in writing an objective review, small as they are, these are the only "flaws" I found:
-Couple very small scratches in the paint where the turf was trimmed with a razor. Seriously cannot see them standing in the boat, noticed them vacuuming it out. I have scratched it far more it the week ive used it. -The Starboard plug rubs the bottom of the boat just a little when tightening it. No big deal, but got a different style (factory had the little "t" screw) for $3, "problem" solved
These are seriously things that I don't know if many other people would notice, but I was so happy with the boat I tried to find any flaw just to be objective for this review. Even as particular as I am I am 100% happy with the rig, its as close to perfect as possible in my opinion. I do have quite a bit of money into it so trust me, if something wasn't right I would say it.
Thanks again Chad, Ashley, and the whole crew at Prodigy Boats, I couldn't be happier with the amazing quality product you all delivered for me!!!
Will post tons of pics under this post.
_________________ 2015 Prodigy 1954 V-Rake w/GTR35 (heads, cam, exhaust, EFI) Full Review of My Rig Here:
Sat May 30, 2015 9:00 pm |
mikecatt13
 Re: Prodigy 1954 w/GTR 35 w/Heads, Cam, Exhaust, Ecotron EFI
Only letting me post 3 pics at a time but here it goes...
Sat May 30, 2015 9:08 pm |
mikecatt13
Movable deck Sections in place for bowfishing
Sat May 30, 2015 9:10 pm |
mikecatt13
Notice the Permanent Reverse Lights, they are sweet for dark launches or putting it the rig away at night as well.
Sat May 30, 2015 9:12 pm |
mikecatt13
GPS, Switch Panel, Light bar
Sat May 30, 2015 9:14 pm |
mikecatt13
Top Pic At Home in Michigan
Sat May 30, 2015 9:15 pm |
mikecatt13
Couple pics on how the moveable decks can be set up as a 3 man layout or a bench for use in a blind in addition to extending the front deck
Sat May 30, 2015 9:17 pm |
mikecatt13
Interior lights and proof that the bowfishing setup works awesome
Sat May 30, 2015 9:18 pm |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
Great looking rig!
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
Sun May 31, 2015 3:45 am |
Bigbuckfever
Joined: Sat May 28, 2011 11:18 pm Posts: 2114 Location: Slinger, WI
That is one awesome set up! I'm planning on building a winch setup like that to go in my spud holes. It appears you thought every detail out!
_________________ Every day I'm paddlin' 1848 Gatortail boat and 37 efi GTR.
Sun May 31, 2015 7:36 am |
micahb
Very nice
Can't wait to get mine
Sun May 31, 2015 7:39 am |
careybrowning
Beautiful boat!
Mon Jun 01, 2015 8:27 am |
HOTSAUCE170
Joined: Thu Jun 05, 2014 11:44 am Posts: 1685 Location: Lake Blackshear,GA
that's an awesome boat man congrats!
_________________ I named my boat RIANNA cause it gets beat up all the time
Mon Jun 01, 2015 8:30 am |
mikecatt13
Thanks guys, like it more every time I take it out!
Mon Jun 01, 2015 9:29 am |
rnelson
Awesome!! My Prodigy is not as decked out as yours, but I am still loving it. Chad and his team make great boats.
Mon Jun 01, 2015 10:47 am |
dphung
Boat porn !!
Mon Jun 01, 2015 10:54 am |
mudxxed
Joined: Thu Sep 05, 2013 4:46 pm Posts: 1398 Location: SE Bama
That boat is sick.
_________________ 1651 Excel/ 35 MB HD: little of dis, little of dat
Mon Jun 01, 2015 1:00 pm |
wade_660
Wow. Looks awesome
Mon Jun 01, 2015 9:01 pm |
midnightmarshwalker
Joined: Sun Feb 23, 2014 2:49 pm Posts: 56 Location: Dickinson, Tx
congrats on the rig. Looks awesome and puts up some great speeds for a big boat.
Mon Jun 01, 2015 9:12 pm |
doubleBanded
Joined: Sun Feb 03, 2013 1:26 pm Posts: 3084 Location: Down South
Sweet rig!
_________________ 1852 Dfou custom 35gtr
Mon Jun 01, 2015 9:38 pm |
FSUDrew99
Joined: Mon Sep 12, 2011 9:50 am Posts: 126 Location: Jacksonville, FL
Awesome looking boat! You'll love your Prodigy for sure...
_________________ 1854 Prodigy/ Black Death 4500 w/ Ceramic Q Muffler/ Wet Sound 10 Speaker Sound Bar/ Rigid Light Bar/ Minn Kota Riptide/ Hydroturf/ LED Cabin Lights
Recent Argentina trip video I put together. Enjoy:
Tue Jun 02, 2015 6:36 am |
kib876
Joined: Tue Dec 15, 2009 8:16 am Posts: 612 Location: Orange, Texas
Tue Jun 02, 2015 6:46 am |
mikecatt13
Thanks guys, definitely love the rig. Forgot to mention that the Ulterra trolling motor (auto stow/deploy, auto trim, etc.) with the I-pilot link is worth every penny. Not only is it cool as hell to just launch your boat, let it hold its spot, then drive it to the dock with a remote and jump on, its been VERY useful for fishing and bowfishing
Tue Jun 02, 2015 9:57 am |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
Congrats
_________________ 1850 & 36pd
Tue Jun 02, 2015 10:12 am |
HOTSAUCE170
Tue Jun 02, 2015 10:37 am |
Frog
Awesome rig man! You've got to be happy with that!
_________________ http://www.gatorglide.com/
gatorheads@comcast.net
Tue Jun 02, 2015 6:40 pm |
mikecatt13
Tue Jun 02, 2015 8:05 pm |
Fooshman
Joined: Mon Jan 27, 2014 7:39 pm Posts: 97 Location: Black Dog, TX
Good looking boat.
_________________ 2015 GatorTrax 1750 /2015 GatorTail GTR35.
Wed Jun 03, 2015 7:53 am |
nabes
Joined: Fri Nov 05, 2010 7:19 am Posts: 60 Location: Kansas
There are some well thought out options on this rig. Congratulations. I may have to give them a call.
_________________ #willetcustom 2048, GTR 37EFI
Wed Jun 03, 2015 5:02 pm |
nickjames
Looks like a do it all rig man I can't wait to take delivery of mine
Wed Jun 03, 2015 8:45 pm |
Team Schmo
Joined: Sun Sep 08, 2013 8:05 pm Posts: 814 Location: Montana
Awesome rig mike.. Those back up lights are badass!!
_________________ You can't fix stupid
Wed Jun 03, 2015 8:47 pm |
mikecatt13
Wed Jun 03, 2015 9:20 pm |
mich mud runner
Joined: Sat Aug 23, 2014 6:38 pm Posts: 28 Location: Lansing Michigan
Sweet boat!! I cant wait for mine to be finished! Where at in Michigan are you?
Thu Jun 04, 2015 8:08 pm |
mikecatt13
SE near ann arbor
Fri Jun 05, 2015 5:48 am |
Glades Ranger
Joined: Mon Sep 19, 2011 6:32 pm Posts: 1490 Location: south Florida
Amazing! Now all it needs is a little mud and duck blood on it.  Baptize it with good beer.
_________________ Sailing in the sawgrass /1648 grizzly and Swomp 26.5 EFI
Mon Jun 08, 2015 5:50 am |
idabilly
Joined: Sat Jan 17, 2009 7:17 pm Posts: 617 Location: Idaho
I have personally owned five mud boats and as a former MM / boat dealer have sold many others. I thought I'd seen it all. Your boat is fantastic...nice craftsmanship and customization.
The back-up lights are a very cool idea. Well done. Enjoy.
Sun Jun 21, 2015 8:49 am |
jerimiahw
Joined: Sun Sep 23, 2012 8:10 pm Posts: 1191 Location: chauvin
Very nice boat
Sun Jun 21, 2015 12:21 pm |
brickgw
I gotta say them moveable deck attachments are a sweet idea. Makes me want to sell this crusty ass jon boat of mine and upgrade.
Sun Jun 21, 2015 12:27 pm |
LB200
I was looking at reverse lights the other day to add to the trailer wanted them in the boat also. How are yours wired??
Sun Jun 21, 2015 2:32 pm |
mikecatt13
Sun Jun 21, 2015 6:44 pm |
Users browsing this forum: No registered users and 58 guests |
