It is currently Fri Jun 27, 2025 12:42 am
Reply to topic  [ 14 posts ]
 Gator Glide
Post Gator Glide
Giving the ole gator glide a try on my buddies boat, went on smooth.
Soon to be 16.5x48 Instagator pushed by 25 GTR
Tue Jul 28, 2015 10:43 pm
Post Re: Gator Glide
Did you apply going across or long ways down the boat? Any advice with the ribs?
Wed Jul 29, 2015 1:50 pm
we started going long ways but only the center an far outside sections were wide enough for the roller on 3rd coat we did cross the ribs start at one end and work ur way to the other and its way easier, u have roll the ribs a bunch but its not bad i suggest crossways
Wed Jul 29, 2015 1:58 pm
Nice work kcudslayer. Peel the tape while you have a wet edge. I like to spray the ribs but then roll over it to control how much is on and insure adhesion . Roll up and over the ribs. Also when the ribs are facing up I will do a few more thin coats on the peaks. It naturally wants to thin out on the peaks and that's where the wear will be. Still sould wait 20 minutes between those coats also. Extra coats only on the peaks!
http://www.gatorglide.com/
gatorheads@comcast.net
Sun Aug 02, 2015 5:40 am
thanks frog, it went well, cant wait to do my boat (hurry up Jay) lol tested it out today
and it slides right through the veggies
Mon Aug 03, 2015 11:10 pm
Thu Aug 06, 2015 6:27 pm
No change unless you're in contact with mud, dirt, grass, etc. Doesn't change sliding in water.
Thu Aug 06, 2015 7:14 pm
yep no different except turning in the grass then its slippery
Thu Aug 06, 2015 8:17 pm
Fri Aug 07, 2015 9:39 am
Probably so, that Alumacraft probably isn't heavy.
-Custom pool noodle
-stage 4 water wings
Fri Aug 07, 2015 9:41 am
No...it's not. More like an old tin can!
Fri Aug 07, 2015 10:03 am
If you wanted to do it with a hoist, just set the motor on a saw-horse, hang the front from a tree, and pick the back up with the engine hoist. Seen that done too ;)
Here's how I prefer to do mine lol
-Custom pool noodle
Fri Aug 07, 2015 10:08 am
Fri Aug 07, 2015 7:46 pm
I defintely need to GG my boat!! After this weekend I need all the slip I can get. Low water, thick grass and hard bottom had me stove up pretty good. Got stuck yesterday and ended up throwing a load of lumber overboard to lighten the load to get back to the camp 200 yards away. Almost overheated in the process. Went back this morning for a second attempt. Once reloaded with half of the lumber the boat was sitting flush on the bottom and just couldn't get it moving. Dont have reverse, so didn't have that option to dig a trench to get moving again(tho I doubt it would have helped). Maybe, had I been able to hit the pond with some momentum, I might have been able to keep it moving. GG may have helped......maybe.
Sat Aug 15, 2015 7:00 pm
Users browsing this forum: No registered users and 192 guests
