It is currently Sat Jul 05, 2025 11:07 am
[ 6 posts ] |
What's the best prop for a stock 35 sd
mranderson27
What do you fellas think the best prop for a stock 35 hp surface drive?
Thu Sep 24, 2015 11:22 am |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
 Re: What's the best prop for a stock 35 sd
What kind of motor you running?
Thu Sep 24, 2015 12:03 pm |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
I recommend two of these per power unit.... http://bblades.com/shop/brand/pro-e-t/
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
Thu Sep 24, 2015 12:44 pm |
mranderson27
I run a Beavertail surface drive. I bought a mud buddy big blade and it has a great hole shot but struggles a bit to turn that big prop under a load and don't get full rpms..
Thu Sep 24, 2015 6:01 pm |
Russ
Not much else. The gt prop is similar. You could go to an 11x10 (which was standard on the 27 range of engines). If your 35 can't turn it, and beavertail doesn't have an option for you, might try checking compression and leak down on your engine. In all likelihood, your valves are leaking. A stock 35 shouldn't have any real issue turning a big blade or gt prop.
Thu Sep 24, 2015 6:05 pm |
bueller
I have a Big Blade 12x10" 10p on my Beavertail and it runs about 3650 also so I don't think that's just the way they are.
_________________ 1754 Beavertail - 35hp SD
Sat Sep 26, 2015 5:39 pm |
[ 6 posts ] |
Users browsing this forum: rob_rides_03 and 65 guests |
