It is currently Tue Jun 17, 2025 9:52 am
Reply to topic  [ 27 posts ]
 My new to me less than 5 K duck rig
Post My new to me less than 5 K duck rig
MM Brand: Backwater 27 EFI swomp Koehler 2012 bought used
Horsepower:27
Boat Brand: flat bottom Weldbuilt
Boat Size: 1648
Boat Layout: all open except 30" front deck and 2storage pods in rear
Speeds | Shallow Water: haven't run any skinny water yet
Speeds | Deep Water: 20
Total Boat Load With Gear Etc: full gas tank in front dozen decoys me (230) and buddy (170) other misc duck hunting gear guns bags boat blind (banded axe) etc.
Conditions Tested In: light chop Ohio river good stiff current defiantly ran smoother & faster downriver
So far I like this combo its is my first MM so bit of a learning curve so far.
Some y'all tell me if my speeds are good? Happy with 20 but if co can get more .......?
All I care about is killin Ducks and like 4 people and my dog!
Wed Nov 04, 2015 9:56 pm
Post Re: My new to me less than 5 K duck rig
Man, you're not going to get much more out of that rig. I'm actually surprised, I figured you'd get that with less of a load.
Thu Nov 05, 2015 12:34 am
You are doing pretty good with what you got, the best way to tell if you can get more out of it is to check your rpms running at WOT in the water
Thu Nov 05, 2015 6:53 am
Going to order the tach for my motor in the next few days. It does seem that I could get a few more RPMs?
Thu Nov 05, 2015 9:27 pm
I don't know if you'll get more out of it. Those are pretty good numbers but the tach will tell. You may fool around with the prop just to find out it was already setup well enough.
Thu Nov 05, 2015 9:37 pm
That is ideal, enjoy that combo! Wear the kill switch lanyard, get plenty of practice, and ease into the turns. Gatorglide/steelflex the bottom; hydroturf the floor; you will have a regular mud motor Cadillac! Ibuprofen goes good with strong coffee.
Wed Nov 11, 2015 12:24 pm
Definitely talk to the guys at Backwater when you are trying to dial in your setup. I have a swomp also and they are some awesome guys.
Mon Nov 23, 2015 10:04 am
So I got the tach the other day. Got it set for the v twin and says I am at 3600rpm out of water at WOT. I think that's the factory setting on the fuel injected kohlers? Going to run it Wednesday to scout and will see what I am getting in the water.
Mon Nov 23, 2015 10:37 pm
Ran it scouting the other day it's like 3380 rpm in the water just me and dog. 19 mph
So I guess my RPM s are where they should be ???
Sat Nov 28, 2015 9:25 pm
Lightly loaded you want your rpm closer to 4000, a little more than that won't hurt. Sounds like you need to look at cav plate adjustment, and weight distribution in your boat. What prop did it ship with?
-Custom pool noodle
-stage 4 water wings
Sat Nov 28, 2015 11:09 pm
Sun Nov 29, 2015 9:49 pm
Mon Nov 30, 2015 7:08 pm
I had the same problem. I fixed it by taking a little slack out of the throttle cable so I now get full travel on the throttle linkage.
Tue Dec 01, 2015 10:32 pm
Wed Dec 02, 2015 8:46 pm
Glad u got it figured out! I was toppin out at 3400 rpm and adding those extra 3-400 rpm added a couple mph.
Thu Dec 03, 2015 10:08 pm
Sat Dec 05, 2015 4:00 pm
So what happened after tweaking the throttle? My next longtail will definitely be a BackH2o! Test drove a 35 swomp this summer, definitely a beast, not sure I want that much weight on the transom of my 1648, a bit harder to turn, might just stay with the 26.5 (formerly 27). A fine product!
Sun Dec 06, 2015 6:34 am
Sun Dec 06, 2015 7:16 am
Ok, good luck! We re-start on the 12th; I am running a 9x6 prop, getting a few more rpms, 1-2 mph more than the 9x7.
Sun Dec 06, 2015 8:31 am
So last couple runs here is what happened....... Deep water just me and a blind.& full gas tank ran 20 mph upriver I am happy with it cause it look like that all I am going to get. I was able to run with a pretty good hunt load in shallow water yesterday and got it to plane out run about 15 mph had three guys 230 , 200 & 160 . Had a dog all the bags and seats 4 dozen decoys all in all a hell of load for a 1648!
Sun Dec 20, 2015 10:41 am
Tue Jan 12, 2016 10:41 pm
To repeat again, you've got a great hunting/fishing tool; add a trolling motor in the off-season of course. Dollar for dollar, that motor is a great deal- powerful, reliable, albeit slower than a high-falooting surface drive mm, but nothing to be ashamed of. Enjoy the ride, let those ADD monkeys with their loud mufflers and umpteen horses scare all the ducks out of their marshes! :mrgreen:
Wed Jan 13, 2016 7:54 am
I've never figured out why the hell do ppl run loud mufflers? I can motor into my duck hole and not even bump all the birds out with my stock quiet muffler. Quiet is a advantage.
Sat Jan 16, 2016 8:23 am
The loud is to make up for certain inherent deficiencies.... :mrgreen:
Mon Jan 18, 2016 8:46 am
Mon Jan 18, 2016 5:04 pm
Tue Jan 19, 2016 6:49 am
I was thinking more along the lines of something's size lol
Fri Jan 22, 2016 1:43 am
Users browsing this forum: No registered users and 64 guests
