It is currently Sat Mar 28, 2026 11:42 am
Reply to topic  [ 13 posts ]
 Predator motor 22hp please help!!!
Post Predator motor 22hp please help!!!
Guys I have a few questions for you. My predator mud buddy swap turned out great. I am now however running into issues where my motor cuts right off after about 30 to 45 Seconds of running on plane. I am not sure if this is a fuel related issue or possibly a low oil shut off issue even though the oil is within spec. I have a video on my phone that shows it happening but it won't load on the page. If anyone can help me it would be great. This is a huge pain being though I can barley go above idol without it cutting off. Thanks again guys!
Mon Dec 07, 2015 3:24 pm
Post Re: Predator motor 22hp please help!!!
ok, so narrow it down. First unplug the low oil pressure switch and run it. if still occurs try having someone pump the fuel bulb while running. This will narrow those two issues, also are you using a new style tank?
Sat Dec 12, 2015 6:55 pm
I have the same motor on an sps kit. The gas was running through 2 filters and the bulb and would cut off probably like 10 seconds after planing off. I replaced one of the filters with an electric fuel pump and haven't had any problems with it since. The only downfall is having to turn the pump on every time you want to go fast.
Mon Dec 14, 2015 8:32 am
I want to say that's right that's what I had to do to my long tail predator engine to put a fuel pump on it once I put the fuel pump it's like a whole new motor got the pump at Napa $57 littleexpensive but it was worth it because it works perfect now
Tue Mar 15, 2016 5:27 pm
I had the same problem and a fuel pump fixed it. This question is off topic but any idea on an oil filter number for this engine
Wed Mar 16, 2016 9:50 pm
51394 wix
Or crossover equivalent.
Thu Mar 17, 2016 1:33 pm
Don't let the parts people tell you otherwise. They'll try to give you the filter for a gx670 honda and it's wrong. The honda has 20mm threads and the predator has 3/4. Not much different but enough it ruined my filter adaptor and I had to wait 3 months for a new one
Thu Mar 17, 2016 1:36 pm
Thank you sir
Thu Mar 17, 2016 2:53 pm
I went to AutoZone and got original one from factory they looked it up on Google for me and then ordered it same one it's perfectonly about 6 bucks apiece I ordered two
Sun Mar 20, 2016 10:19 pm
have same motor with same issue. what gph fuel pump did you go with and did u wire it directly to ignition or better on a toggle switch?
Mon Mar 21, 2016 8:22 am
I'm thinking a 2-4 psi pump would be enough. Guy in a different forum said this one works.
http://m.oreillyauto.com/mt/www.oreilly ... t_redirect
Mon Mar 21, 2016 8:31 am
Jake do you happen to know the air filter # cross refrance I have searched with not much luck other than the Honda filter for $35.00.
Sent from my HTC One using Tapatalk
1654 GDSD 37efi.
Thu Mar 24, 2016 11:36 pm
2-4 psi is what I'm running wired into the key switch with a waterproof relay. One less thing to worry about turning off
Wed Apr 13, 2016 9:32 pm
