It is currently Wed Apr 08, 2026 6:00 am
Reply to topic  [ 17 posts ]
 How to get clutch off of 32 PD
Post How to get clutch off of 32 PD
How the HELL do I get the clutch off of my 32 pd. I am trying to put a new sump gasket on and cant get that mf off. Any and all help is greatly appreciated. Pullin my hair out here.
tom
1648 PD
32pd
Sat Mar 06, 2010 9:54 pm
Post Re: How to get clutch off of 32 PD
have you taken the "stub shaft" with the 4 socket head bolts off yet?
Sat Mar 06, 2010 9:55 pm
You might be waitin a while for an answer. All the pd guys are getting sauced up right now at the loureville state park! :lol:
Sat Mar 06, 2010 9:57 pm
How many hours does it have and when was the last time it was pulled off. If it wasnt put on with anti get stuck and piss you off stuff it will be a biatch. Its gonna take some pry bars and hammers but dont get to rough with it.
BUCK OFAMA
Sat Mar 06, 2010 9:58 pm
I have taken the tiller handle assembley with the engine atached off of the lower unit. The tiller handle braket and the clutch are still hooked up to the engine. It remoce the 4 bolts that attach the engine to the tiller handle/ reverse section off and the clutch is stuck to the engine shaft. had a 3ft pry bar on it and it still wont come off.
1648 PD
32pd
Sat Mar 06, 2010 10:02 pm
Your gonna need to pry on both sides of the clutch at the same time not just one. If it dont come off go get a three jaw puller before you break somthing. I had the same issue. Craig did to and ended up needing another before it was all over.
BUCK OFAMA
Sat Mar 06, 2010 10:08 pm
You did remove the bottom bolt on the clutch?
18x48 Charles Leonard / 36PD
Sat Mar 06, 2010 10:34 pm
Poker, what bolt on the clutch? I looked all over on it and all that I see is the shaft that goes to the lower unit and the clutch itself. the reverse plate is still on the motor. The bolts are off and the clutch wont come free even with pressure on each side. This REALLY is PISSING me off
1648 PD
32pd
Sat Mar 06, 2010 10:45 pm
Once again, as ever been removed. Im telling you man, they can be a serious bitch if installed dry or have been on for a long time.
BUCK OFAMA
Sat Mar 06, 2010 11:04 pm
No, never been removed. Its got 204 ish hours on it. Sump started to leek after 50 ish. Just trying to fix this problem before I put on a Big Johnson Manufacturing " stage one" kit. My buddy is a machinist and work at a marine sales and service center in WI. Mechanic is one of 3 master techs in the tri state and he is doin the hop up form me. we were takin it apart after wook tonight and all we have so far is greiff. While im in there I am replacin the lower and upper seals on the lower unit and rotating the nylon sleve in the center section. looks like it will be a long day tomorow. Keep advice comin it is greatly appreciated and welcome. Thread jackers are even welcome if there is some help.
tom
1648 PD
32pd
Sun Mar 07, 2010 12:07 am
I changed my clutch about 2 weeks ago. I had to use a 10 lb. mall to get it off!!
Word of advice..................If you end up having to pry and beat on it to get it off you best replace it with a new one cause it won't last but a couple hours.....if that!
Don't ask me how I know this.
Sun Mar 07, 2010 6:59 am
pm sent
Don't mistake my kindness for weakness, my ability to look over things as ignorance - but make no mistake, when I've had enough, I'm Coming After you. Watch Your Back....lol
Sun Mar 07, 2010 7:02 am
BUCK OFAMA
Sun Mar 07, 2010 8:13 am
Sun Mar 07, 2010 8:24 am
Sun Mar 07, 2010 8:53 am
It is very easy to remove!Make 2 wedges out of wood and drive them in on both sides of clutch ;)
Sun Mar 07, 2010 10:00 am
Got the beeach off this morning. Took some enginering but it came off. that sucker seemed like it was welded on!!! Replace all lower unit seals and rotated the color inside of the lower unit (my tension wheel didnt work form day one), replaced sump gasket and intalled heads after they were decked and shimmed, replaced all fluids(oil and lower unit gresse), put on reworked intake and had it runnin in 4 hours. Thanks for all the help it was needed and appriciated.
tom
1648 PD
32pd
Sun Mar 07, 2010 9:54 pm
