It is currently Sat Mar 28, 2026 6:25 am
Reply to topic  [ 21 posts ]
 Trolling motor and light bar
Post Trolling motor and light bar
Do any of you guys have a trolling motor and light bar mounted at the same time or is it only one of the two? I would like to be able to mount my trolling motor without having to remove the light bar every time.
Wed Feb 03, 2016 6:51 pm
Post Re: Trolling motor and light bar
Just mount the light bar on one side and the tm on the other. Many pics floating around here of rigs with both.
Wed Feb 03, 2016 6:59 pm
It works just have to play with how you position them both
Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust
Pushing a 17X54 Pro-Drive X-Series boat
Wed Feb 03, 2016 7:42 pm
I've got both. My light bar has sliding mounts along the bottom and is mounted very slightly off center. I took the time to mount it so it wouldn't get in the way of the trolling motor and wouldn't stick out past the gunnels and get knocked off by a tree. The 22" bar worked out perfect on the bow of the boat.
-Custom pool noodle
-stage 4 water wings
Wed Feb 03, 2016 8:00 pm
I've got both. No problems. Lightbar is centered.
Wed Feb 03, 2016 8:03 pm
That prodrive looks good but I don't think mine will be that easy. I have a 2010 Excel shallow water and it doesn't have near as much room in the front.
Wed Feb 03, 2016 8:09 pm
I have 12" bar. It's more than enough light for driving. Has no effect on trolling motor. It also will fit between the bowfishing rail supports on the bow.
Wed Feb 03, 2016 8:12 pm
I don't have pictures on my phone, but I have both up front. 12" bar centered and trolling motor.
Every day I'm paddlin'
Wed Feb 03, 2016 8:24 pm
Wed Feb 03, 2016 8:48 pm
I'll snap a pic tomorrow, mines pointed and it all fits fine.
-Custom pool noodle
Wed Feb 03, 2016 8:50 pm
Mine is pointed bow, too.
Wed Feb 03, 2016 9:25 pm
Angle it so that it misses the light bar. The head may be over the deck when not down but looks like you got plenty of room for the base mount and be careful when pullin it in
Wed Feb 03, 2016 10:54 pm
Get a smaller bar!
Sent from my beeper
Thu Feb 04, 2016 7:00 am
Thanks for the advice guys and for the pics. I may end up having to get a smaller light bar.
Thu Feb 04, 2016 9:00 am
Got my lights set up on a ram mount to get em above the trolling motor.IMG_20151005_170524.jpg
Fri Feb 05, 2016 9:21 pm
There's some real groundbreaking shit in this thread.
Fri Feb 05, 2016 9:56 pm
Well at least your on the front line
Fri Feb 05, 2016 10:32 pm
forgot to add the picture. Not pointed bow, but I don't see how that would make it not work.
Sun Feb 07, 2016 9:30 am
I got a pointed bow as well and you really can't fit a bar and trolling motor. I'm about to pull my light bar off and go back to my golight. It seemed to work better then this led bar does. It's usually foggy on the water early morning and all the white light does is blind you
Sun Feb 07, 2016 9:48 am
Could get something like this made
Sun Feb 07, 2016 9:50 am
May not be what you were thinking but this could be an option much like the Ram mount above considering space is of concern with your current light bar. Swivel seat base bolted to the light housing and inserted into the post. Allows me or a buddy to rotate the light whichever way when driving or in the hole. Also great to spin around when backing down the boat ramp. Simply unplug, remove light, store away then re -attach seat and back to fishing in your case.
Tue Feb 09, 2016 2:11 pm
