It is currently Sun Mar 29, 2026 12:54 pm
Reply to topic  [ 15 posts ]
 Godevil 24hp
Post Godevil 24hp
I have a 24hp Honda god evil was out riding to day and found the top of the shaft was hot it had grease in the cup why would this happen it was after the u joint
Fri Mar 11, 2016 10:35 pm
Post Re: Godevil 24hp
They get hot quick. Also, just because there is grease in the cup doesn't mean it's working.
Sent from my SAMSUNG-SM-G890A using Tapatalk
17'Extreme Metal Fab. Skiff - 23 GDLT
Fri Mar 11, 2016 11:32 pm
How hot dose it get and how do I make sure it's greasing I'm new to long tail
Sat Mar 12, 2016 6:15 pm
They all get hot. Not so hot it burns you but hot like a hot bath. And there should be grease zirts on the shaft of your longtail. Pump it until you see the grease level I the cup rise
Tue Mar 15, 2016 5:02 am
Sorry didn't see you replied back. Yeah, what he said. I've never touched it after running so don't really know.
That stopper in the auto greaser should rise when you pump grease.
Don't pump in the zert that's connected directly to the auto greaser. Use one on the shaft.
If you want you can let it idle for a little while and get the old grease hot so the new grease can flow in there better.
Tue Mar 15, 2016 6:22 pm
Mine gets hot like u can't touch it what would cause this
Tue Mar 15, 2016 8:08 pm
Friction
Tue Mar 15, 2016 9:13 pm
Genius idea^^^
1754 prodigy- stage 2 GTR
Tue Mar 15, 2016 9:17 pm
You don't have enough grease in your shaft.
Wed Mar 16, 2016 5:03 am
While you're running it you inevitably lose grease. If you run for over an hour when playing or fishing or whatever. You should grease it. When u get done. My runs are usually only 20-30 minutes at most. I grease after 2 trips. If I'm playing I'll grease it when I'm done or before I go out again. And it takes alot of fuggin grease to fill the shaft for the first time. Better have strong fore arms or an automatic grease gun of some kind. My guess is you have a bushing that's almost if not already turned to shit if you have that much heat. If your prop wobbles you should start googling how to put in new bushings.
Wed Mar 16, 2016 5:06 am
I don't grease mine nearly that much. I watch the "float" in the greaser. When it goes down I add a few pumps.
If you grease it all the time you risk blowing out seals or they are already blown out.
I run mine pretty much every weekend from Oct to Feb.
Wed Mar 16, 2016 8:25 am
I made mine and my top and bottom don't have seals. My bottom is a shaft end bushing it doesn't leak so bad. my top is a flange bearing and for some reason the grease pushes out thru the bearing. In my build I figured making a flange for the flange bearing to sit on and making a gasket for it would keep grease in, not sure if that's flawed logic or the seal on my bearing was bad right out of the gate. So I leak probably 2 ounces every run.
Wed Mar 16, 2016 10:03 am
I did have grease come out the top of the shaft how much are the bushings and are they hard to but in is there any thing else i need to check I run the boat year round in the summer I run 30 min one way will this hold up to this I'm all new to the long tail
Wed Mar 16, 2016 8:21 pm
They are not too bad. Sounds like you have never read the owners manual though. It's on go devils website, pdf file. You need seals and probably bushings. The top will get hot, if it's not burning the paint off the shaft your probably okay. The manual will have instructions on how to change everything. Please use the search feature when you can't figure out how to remove the prop. Are you losing any grease on the prop end? Is there grease on the shaft between the shaft housing and prop?
You will have to have your serial number ready when you call go devil to order your parts. It's stamped on the frame right under the U -joint.
Thu Mar 17, 2016 3:33 am
Just got the motor used so no I need to look at the manual the shaft is only leaking grease at the top of the shaft nothing at the prop
Fri Mar 18, 2016 7:24 pm
