It is currently Wed Sep 24, 2025 2:31 am
Reply to topic  [ 19 posts ]
 Gen 3 or 4 PD lower unit?
Post Gen 3 or 4 PD lower unit?
How can you tell if a PD has a gen 3 or 4 lower unit? What are thw gear ratio for both?
Tue Jul 05, 2016 7:27 am
Gen 3 is a 2:1 ratio
Gen 4 is a 1.52:1 ratio
I could be wrong but I think the 4 has a hex shaft and the 3 does not.
Tue Jul 05, 2016 7:33 am
There are no Gen 4's. Only Gen 3's with two different gearing options....noted above.
Tue Jul 05, 2016 8:11 am
Post Re: Gen 3 or 4 PD lower unit?
Tue Jul 05, 2016 8:34 am
Prodrive can probably tell you....or tell us what speeds your getting on what size rig....the majority will figure it out real quick.
Tue Jul 05, 2016 11:38 am
There is a way to tell, apparently there is some kind of marking on the L/U. I can't remember what it is though...
PD 1754 X Series and a PD 37EFI
Tue Jul 05, 2016 11:41 am
I saw one this weekend. It'll be right under the gear box on the lower unit on the oil filter side. I swore it said gen 4. Could be wrong. Would the hex shaft not give it away, or does a gen 3 have a hex?
Tue Jul 05, 2016 11:51 am
Did PD go from splined to hex?
Tue Jul 05, 2016 12:38 pm
Tue Jul 05, 2016 12:45 pm
They have a tapered splined shaft not a hex
Sent from my SAMSUNG-SM-G890A using Tapatalk
Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom
Jus nut up and grab a handful of throttle
Tue Jul 05, 2016 4:22 pm
I stand corrected. Carry on
Tue Jul 05, 2016 4:44 pm
Tue Jul 05, 2016 6:07 pm
Uh oh. Blue, what you think that g4 stamp stands for?
:lol:
Tue Jul 05, 2016 6:10 pm
It's stands for "Blue is getting his lower unit yanked by pd" :)
Tue Jul 05, 2016 6:15 pm
I stand corrected, then. PD needs to update their manuals!
Tue Jul 05, 2016 7:45 pm
How much cost/trouble is it to convert one from a 3 to a 4?
Wed Jul 06, 2016 5:24 pm
If you got a way to suspend the engine for a few minutes (preferably an engine hoist), its pretty easy. Maybe a 30 minute job. Lil more the first time you do it, lil less if you've done it before.
Wed Jul 06, 2016 5:50 pm
Last time I checked on cost, it was $1500 for the part. That was back when they introduced the 1.52:1 part.
Thu Jul 07, 2016 8:53 am
Fri Jul 08, 2016 11:55 am
cron
