It is currently Sat Mar 28, 2026 3:08 pm
Reply to topic  [ 9 posts ]
 Throttle lever suggestions?
Post Throttle lever suggestions?
I'm looking to add a surface drive style throttle lever on a swomp lite 23.
Idk the diameter of the handle, I emailed backwater and awaiting a response.
I did find a 7/8 dirt bike clutch lever, is this about the right size for the handle on the frame?
Anyone else did this kind of mod? An what did you utilize?
Going to Disney World is like Going To the DMV, Instead of Walking out Once Finished Jumping Back In Line At the DMV…
Wed Jul 06, 2016 6:23 pm
Post Re: Throttle lever suggestions?
Measure the handle diameter. See if it's 7/8 or not.
Wed Jul 06, 2016 7:12 pm
Yea, I didn't receive the motor yet it's in route from MN to south la
Wed Jul 06, 2016 7:46 pm
No the 7/8 will not fit. I'm in the process now of installing a lever type throttle. The pipe or whatever you use that fits the 7/8 lever will actually fit inside the handle on the swamp lite 23. I'm debating to either weld it inside or attach like Huck did his. I'm asking Huck for info now on another thread...might tune in.
Wed Jul 06, 2016 8:04 pm
I couldn't find anything nor info on the Web to help me.
I did order a 7/8s clutch handle but the bar is 1"outer diameter.
So I am going to cut an weld then reform the lever to a 1" pipe.
In theory.
Thu Jul 07, 2016 12:16 pm
In theory.
Thu Jul 07, 2016 12:17 pm
Hi, the tubing diameter in the handle of the Backwater is 1 1/8", in motorcycles or bicycles normaly they use 1" and 7/8". I found this in EBay. Using a dremmel tool you can open the inside to make it fit. And order a bicycle brake cable .
I bought my in Ebay long time ago from a Co. name (ebay name) BUILT YOUR BIKE.
Copy this titles and search in Ebay.
Fit BMX BIKE BRAKE LEVER Right Fit OLD mid &new SCHOOL BMX bars level 1 Takeoff[
Mini Chopper Mini Bike 1"one inch Brake clutch Lever
1 Pair Cycling Bicycle Road Bike Handle Hand V Bar Brake Lever High Quality
Hope they help.
p.b.
Thu Jul 07, 2016 12:43 pm
I'm sure the gatortail lever or the godevil surface drive lever has been tried out alreadyon a swomp 23?
Thu Jul 07, 2016 4:36 pm
The bps can be made to work on the swomp handle. It has enough throw length . It's what I use from dead idle to Wide ass open.
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Thu Jul 07, 2016 6:42 pm
