It is currently Tue Apr 07, 2026 1:12 am
[ 6 posts ] |
tmschuster
 Compression question
I own a stock 2013 mud buddy 35hp with 70 hours and I just found out that some how I had water in my oil and gas (not really sure if it was a kid walking by the boat or just condensation). I tried to start my motor on the lake and it was running very poorly. I put it back on the trailer and changed my oil and it was a milky yellow. I also put brand new gas in the motor. The engine seems to idle and run good now but I decided to check my compression. The the left side where the oil fill is reads 99 and the other side reads 87. What should the numbers be? What would be considered needing replacement?
Thank you
| Mon Jul 11, 2016 5:56 pm |
OwenDickeson
 Re: Compression question
Did you check it with the throttle completely open?
Sent from my XT1254 using Tapatalk
| Mon Jul 11, 2016 6:01 pm |
tmschuster
I just retested the the compression holding the throttle and it says 124 and 130
| Mon Jul 11, 2016 7:20 pm |
BlueShamu
When my PD was stock, I had 125 on one cylinder and 130 on the other.
| Mon Jul 11, 2016 7:32 pm |
brycecheramie
cb5331
junk
| Mon Jul 11, 2016 7:37 pm |
[ 6 posts ] |
