b_coonass
Joined: Thu Mar 26, 2009 2:08 pm Posts: 1229 Location: morgan city, louisiana
 shaft stuck on u-joint
My upper seals on my LT are out an i tried changin them put i cant get the shaft out of the u-joint! I even tried heating up the outside of the u-joint but no luck! Any suggestion on this??
_________________ 36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
| Mon Mar 15, 2010 6:30 pm |
Jim1648
Joined: Sat May 02, 2009 4:24 pm Posts: 115 Location: Michigan
 Re: shaft stuck on u-joint
You can rent a slide hammer bearing puller or axle puller(whatever it is) from autozone for free. That's what I have used with good results...
| Mon Mar 15, 2010 6:59 pm |
Tenpoint
Joined: Thu Aug 27, 2009 5:22 pm Posts: 2029 Location: Patterson LA
_________________ 19x48 Rink/Aucoin Bateau w/35 GTR 20x60 Home-made skiff w/200 Merc
| Mon Mar 15, 2010 7:01 pm |
b_coonass
| Mon Mar 15, 2010 7:09 pm |
caddobrook
Had same problem.
Heated it with blow torch. Came right off.
You might try heat again and make sure you get it hot...
| Mon Mar 15, 2010 7:17 pm |
b_coonass
| Mon Mar 15, 2010 8:24 pm |
kibb
You aren't gonna get it hot enough with propane. Go with oxy-acetylene.
| Tue Mar 16, 2010 5:00 am |
b_coonass
| Tue Mar 16, 2010 5:55 am |
10shotgroup
I use a long tapered punch. Drive the punch between the u joint and the shaft. The wedge shape will force the u Joint off. When you run out of shaft to push on remove the wedge and place a nut that fit in the shaft opening on the ujoint. This will drive the ujoint the rest of the way. Your other option is to dissamble the ujoint by removing the clips on the inside ofthe ujoint pins.
| Tue Mar 16, 2010 7:06 am |
bundy
Joined: Sun Apr 05, 2009 8:35 pm Posts: 1232 Location: souf louisiana
just bring it by the shop jackass!!!!1 and we wil get it off.. and no im not coming pick the boat up..
_________________ BUNDY BUILT SKIFFLESS cuz der bad ass like dat....
bunnny rabbit customs.
| Tue Mar 16, 2010 8:05 am |
EasTexDux88
Joined: Tue Sep 29, 2009 3:08 pm Posts: 1069 Location: Longview Tx
slide hammer works the best. just put a spacer between the u-joint and shaft housing so your not hammering against the motor shaft
_________________ ETD88 09/28/09-05/14/2010...
| Tue Mar 16, 2010 8:47 am |
