It is currently Sat Apr 11, 2026 11:13 pm
Reply to topic  [ 9 posts ]
 Replacement for 23hp GoDevil
Post Replacement for 23hp GoDevil
What's my best option for putting a new motor on a GoDevil?
The 23 Vanguard I have on it with 165 hours has scorched cylinders.
I was thinking a Predator 22 HP if it will line up? If I decide to sell, how much is the tail worth, without a motor (or the one that is shot)?
Wed Aug 10, 2016 12:00 pm
Post Re: Replacement for 23hp GoDevil
I would buy the Predator and not look back. If you go that route, message me for some tips. I set one up on a Backwater that has over 100 hours now and no problems. It ran great. (sold to a friend) The dimensions on the two are the same.
What year is the GD frame? My first thought would be under 1,000 dollars. I base that off buying a brand new Backwater frame for 1700+ shipping. Just my opinion.
Wed Aug 10, 2016 12:18 pm
It's a 2003...
How much work am I looking at for the swap, and how big of a PITA? Should I expect good speeds from the predator? On a 16x54 modv
Wed Aug 10, 2016 12:21 pm
If your willing to ship that dead 23 to Texas I'm intrested $
Wed Aug 10, 2016 5:49 pm
Shouldn't be too much work - a few hours tops. Disconnect the throttle linkage and battery connections, disconnect the bracket supports for the longtail, slide the u-joint off the crank, remove the 4 bolts from the base plate. I swapped engines on a Backwater and it took less than an hour. It should be similar. The Backwater was probably a little more time consuming than a GD would be.
Thu Aug 11, 2016 5:21 am
And not to rain on your parade, but if it was my frame and I was hoping to sell it - I'd be happy to get 500 for it knowing its a 2003.
Thu Aug 11, 2016 5:22 am
Will I be able to hook my hand throttle up to the predator?
Thu Aug 11, 2016 7:38 am
yes, same carb connection
Thu Aug 11, 2016 12:18 pm
Why not rebuild the 23? PVT could help you out, he has take off parts available from his performance builds.
Fri Aug 12, 2016 9:10 am
