It is currently Fri Apr 03, 2026 9:33 am
Reply to topic  [ 11 posts ]
 Hoisting engine
Post Hoisting engine
GTR 37, i need to remove it from my transom. I do not see any lift points on the motor. There are 2, what appear to be lift points, near the valve covers. i assume this would be just for lifting the motor, not the frame and drive. I know someone has experience with this, advice would be appreciated.
Thanks in advance
Wed Aug 17, 2016 7:33 am
Post Re: Hoisting engine
You can use those points to lift the entire frame.
Wed Aug 17, 2016 7:40 am
I used the points you speak of to lift it off and and put it on a stand with no issues, but not sure how well they would hold up of you are looking at leaving it hanging from those points. Just my .02
Sent using smoke signals
15/42 Alweld 25 MBLT
Agreed. Much stronger than they look
Wed Aug 17, 2016 10:09 am
Mine bent when the engine was lifted off with them. I go through the frame below the motor now when taking my gdsd off. A regular engine stand works great for storing it when it's off too
Wed Aug 17, 2016 12:52 pm
Yeah they'll bend a Lil to the inside the first time, but leave em bent and use em.
HOTSAUCE170 wrote:
Wed Aug 17, 2016 5:18 pm
I hung my prodrive from those same eyes, for a week.
The are a lot stronger than they look.
Wed Aug 17, 2016 7:00 pm
-Custom pool noodle
-stage 4 water wings
Wed Aug 17, 2016 7:46 pm
Wed Aug 17, 2016 8:33 pm
That's how GD totes them around and how I was told to pick it up I ever had to. I've taken mine off the transom a few different times and always used them. I made up a lifting cable with two small shackles and a ring in the center. It picks the whole unit straight up off the transom, they hold it no problem. That's why they're there. I was told by several people NOT to use the brackets on the heads. Those are for the powerhead only. Those bolts are small, thread into already crap aluminum heads. They weren't meant to hold the weight of a frame too. I have known folks to pull them out of the head and have to helicoil the holes.
-Custom pool noodle
Wed Aug 17, 2016 8:48 pm
Emailed Gatortail to get to the root, not sure why i didn't do that to begin with, confirmed the liftpoints on the head will support the entire unit.
Thu Aug 18, 2016 2:32 pm
