FRANKtheTAU
Joined: Thu Dec 29, 2011 10:30 pm Posts: 1386 Location: West TN
 Anyone have a newer GM truck with a 6.0 motor?
Looking at trucks and specifically 2500HD GM gas burners with the 6.0 motor. Everything I'm hearing is the motors are extremely reliable but fuel economy is less than desirable. I believe all the new trucks come with the 4.10 rear end so that doesn't help matters. Does anyone else have anything to say about the trucks our motors?
_________________ 40 Backwater SWOMP Lite / 1752 Alweld Mud
| Wed Aug 17, 2016 6:31 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
 Re: Anyone have a newer GM truck with a 6.0 motor?
I just bought a used one for a road tire truck. I believe its a 2004 with 200,000 mile paid 2700 for it. 3 months going strong.
Sent from my SAMSUNG-SM-G925A using Tapatalk
| Wed Aug 17, 2016 6:37 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
6.0 is about bullet proof. It's the old 366 they put in the ole c65 dump trucks. I had an '03i bought new, sold it in '08 with 280k to a mexicanlandscaper. He's still driving it today. Only thing that ever happened to it was I broke a motor mount trying to pull a stuck bobcat out .
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
| Wed Aug 17, 2016 7:08 pm |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
What year range are you looking at Frank? There's not a bolt I haven't turned on that truck platform. Some are better than others.
To be clear, that is an "LS" based engine. GEN III or GEN IV depending on year. As long as it's pre-'14 when they started direct injection. That's a whole different block, heads etc...
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
| Wed Aug 17, 2016 7:54 pm |
wade_660
Ive had a couple. Oil sending unit screens are the only problem that I recall. Solid engines
| Wed Aug 17, 2016 8:13 pm |
FRANKtheTAU
| Wed Aug 17, 2016 8:48 pm |
SETx Longtail
I haven't done as much on the 14+'s but from all accounts they're solid engines just like the rest. There have been some minor issues and I would recommend doing a top end induction cleaning service every 30K or so. Installing a catch can (correctly) into the PCV system day one is recommended and will keep oil out of the intake tract. The direct injected engines suffer from intake valve coking in some cases since they don't have fuel in the intake runner to keep the back of the valve clean. It's being injected directly into the combustion chamber. Are the 2500's getting the 8spd trans? If you're getting the 6L90E auto, it's a solid unit. Shouldn't have any issues.
They're great trucks, the DI GEN V engines are strong. They have a little more mechanical noise than the older engines simply due to the HP fuel system. Good luck with it. They're great trucks.
| Wed Aug 17, 2016 8:58 pm |
dem0001
My dad has a 99 2500 with 258,000 hard miles on the original 6.0 and transmission and still going strong. Pulled a gooseneck with a 95 Hp tractor last week.
However, don't get me started on my 07 5.3 with 132k. It's receiving a new engine in the very near future and I hope it'll be a 6.0 if I can get it to bolt up.
| Wed Aug 17, 2016 9:00 pm |
SETx Longtail
My 07 5.3 has 135K on it now and has been running like a top. It does have a lifter tap on a cold start if it sits for more than a couple days but it gets quiet fast and has done it since I bought it with 40K. It also gets 15/40 Rotella just like almost everything else I own.  I refuse to put 30w water in that engine. Some of the GEN IV's do have oil consumption problems that stem from the AFM system but that's typically an easy fix. As far as replacing your 5.3L with a 6L, it's an easy swap as long as you get the same generation engine, it's a direct 1:1 swap but you will need retuning. It's a little more wiring but you can put an older (99+) engine in your 07 truck. It's been done. As well as the other way around. I'd be concerned with the 4L70E taking a dump before that engine does though. I have a backup sitting wrapped up on a crate for mine for whenever it decides to go south. With those things, it's when, not if.
| Wed Aug 17, 2016 9:07 pm |
dem0001
I cringe every time I see the word lifter. Mine doesn't even have AFM. Roller seized and is now banging on my camshaft. When it first started I went to autozone to get some rislone and the guy behind the counter goes "let me guess, 5.3 Silverado between 06 and 11."
| Wed Aug 17, 2016 9:22 pm |
FRANKtheTAU
| Wed Aug 17, 2016 9:36 pm |
SETx Longtail
I'll dig up some info on them and post it here. Basically cleans the PCV system that's known for recirculating oil vapor back into the intake. Very easily solved problem though. I have one on my 07.
| Wed Aug 17, 2016 9:57 pm |
Will
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Thu Aug 18, 2016 7:18 am |
SETx Longtail
That's exactly it. I have installed one on every GM engine I've owned and I believe it's probably saved me some grief somewhere down the road. This is the one I recommend: http://www.mightymousesolutions.com/#!m ... cans/w4v36
| Thu Aug 18, 2016 7:25 am |
FRANKtheTAU
Thanks guys!
| Thu Aug 18, 2016 8:03 am |
reharbert
Joined: Tue Mar 17, 2015 1:38 am Posts: 606 Location: Beaumont, Texas
I had a 2013 2500HD work truck with the 6.0. It was a strong truck. Had a service body and was always loaded with lots of tools and pipe.
Gas mileage was typically 8-10MPG, and I don't haul ass either. That was real disappointing, and is the only reason I wouldn't buy one personally.
I had it for about 2.5 years, and put about 80,000 miles on it with no problems.
_________________ Uncle J - 17 x 48 w/GTR | Bayou Surface Drive heads | Voodoo exhaust | DIY Mikuni carb
| Thu Aug 18, 2016 10:39 am |
Glades Ranger
Joined: Mon Sep 19, 2011 6:32 pm Posts: 1490 Location: south Florida
Good luck with the new truck, Frank! I've been happy with my 04 5.3 GMC Sierra 4x4 WT; probably go with the same in a couple of years- but I will also look at Ford...
_________________ Sailing in the sawgrass /1648 grizzly and Swomp 26.5 EFI
| Fri Aug 19, 2016 6:51 am |
MaXXis85
A good engine tune will net more mileage and power from these engines. The 6.0L is severely detuned... Especially in the GMT800 platform.
| Fri Aug 19, 2016 8:27 am |
SETx Longtail
ALL of them are severely detuned from the factory from 99+. We've seen as much as 30hp on 5.3's and one of the LQ9's (6.0) we tuned gained almost 50hp, all with tuning alone. They gained mileage and all around drivability. There's a lot that can be done with them for sure.
| Fri Aug 19, 2016 9:34 am |
MaXXis85
| Fri Aug 19, 2016 10:24 am |
SETx Longtail
You're absolutely right. Tons of potential. That PE table can be awesome when it's manipulated though. I always swapped to an operating system that had a PE and BE (boost enrichment) for forced induction stuff. The E38 PCMs they swapped to had more "driver friendly" type tables but the 0411's are better I think for making real power.
| Fri Aug 19, 2016 11:11 am |
FRANKtheTAU
Got the new truck today. Tried to post pictures but I'm not able to for the first time ever.
| Fri Aug 19, 2016 10:00 pm |
flint87
| Sat Aug 20, 2016 7:11 am |
SETx Longtail
You'd be surprised how many there are living long lives at 500 whp with turbos and prochargers. I had one years ago that I sprayed the hell out of. Never had a moments problem with it. It was a 10 bolt rear eating machine but the engine never missed a lick.
| Sat Aug 20, 2016 8:46 am |
toddh
Joined: Wed Jan 14, 2009 2:00 pm Posts: 428 Location: Hammond, LA
| Sun Aug 21, 2016 6:44 am |
mizzippi jb
Everything out there in the truck market is de tuned. The diesels that are out make ridiculous amounts of torque and hp, but they're dulled down to satisfy the pansy green Prius owners.
| Sun Aug 21, 2016 7:29 am |
mike hunt
What would be the actual mileage you could expect out of a 2016 2500hd with the 6.0? I need a new truck and I'm hearing a lot of reasons why I shouldn't buy one with a dura max, because of the def fluid and the particulate filter. Sorry about the half a hijack, I just don't know anyone with a new gm pickup.
| Sun Aug 21, 2016 8:41 am |
FRANKtheTAU
500 miles on my brand new one and with mostly interstate driving I'm at 14 mpg.
| Sun Aug 21, 2016 2:55 pm |
SETx Longtail
It should improve some. I'd expect 16-17 on a flat highway unloaded as long as you keep the speed reasonable. That depends on final gearing too. All of them I've driven have had 3.73's and 4.10's and done 12 or so in town and mid-high teens on the hwy. GOOD tuning does improve this.
| Sun Aug 21, 2016 3:54 pm |
toddh
| Sun Aug 21, 2016 5:38 pm |
SETx Longtail
That depends on the tuner, and the truck. Anywhere from 1-4mpg is typical. It will vary from truck to truck with the same person tuning though. Just the nature of the beast. Even if there's no mileage gained, there will be more power and better drivability in most cases, so I figure that's a win either way around.
My best advice is if you have someone local that's reputable and will stand behind their work, get a live, in-person street tune done. My second choice would be a dyno tune (preferably on a load-bearing dyno). A mail order is probably a little cheaper but they're usually a generic, canned file the tuner uses and tweaks for small things. They can do a lot thru mail order tuning these days but there's no replacement for being hooked up to the vehicle while it's going down the road.
Main thing is, don't let just any jackass with a laptop plug up to your truck.
| Sun Aug 21, 2016 5:53 pm |
NinjaButtpirate
| Mon Aug 22, 2016 1:06 am |
NinjaButtpirate
The one 6.0 I've drove and been around a lot.... He put a powerdyne super charger on it.... Talk about woke it up!
| Mon Aug 22, 2016 1:07 am |
DenaliHD
_________________ 1848 Uncle J L3 40XD EFI GTR
| Tue Aug 23, 2016 8:47 am |
FRANKtheTAU
Here she is.
| Tue Aug 23, 2016 12:42 pm |
DenaliHD
Looks like mine.. Kinda
| Tue Aug 23, 2016 1:57 pm |
mike hunt
| Wed Aug 24, 2016 9:57 am |
Will
| Wed Aug 24, 2016 10:54 am |
DenaliHD
| Wed Aug 24, 2016 11:26 am |
DenaliHD
| Wed Aug 24, 2016 11:29 am |
