It is currently Mon Apr 06, 2026 4:57 am
Reply to topic  [ 14 posts ]
 37 wiring pic of failed wire
Post 37 wiring pic of failed wire
I thought I would share this one and ask if anyone has any other pics of where the harness fails. This small open it the wire was on the ground wire of the main pump 1" north of the connector. The insulation looked good and you couldn't tell by looking at it.
Thu Aug 25, 2016 12:19 am
Post Re: 37 wiring pic of failed wire
How many hours on your EFI? Thanks for the post
Thu Aug 25, 2016 5:43 am
30 hrs on this one
Thu Aug 25, 2016 8:07 am
Was it causing any problems or you just noticed it damaged?
Thu Aug 25, 2016 8:34 am
How about that hairline crack in the oil filler neck
Thu Aug 25, 2016 8:36 am
This one died on the water. Owner was towed in late in the night. The "crack" was casting flash but did look like a crack
Thu Aug 25, 2016 8:41 am
Junk
Thu Aug 25, 2016 8:43 am
In the pic that does look like a good crack. Can't get away with anything on here :D
Thu Aug 25, 2016 8:45 am
So they just use really shitty wire that's probably also too small? Is it that bull shit that pretty much crumbles if you twist it or try to crimp it?
Thu Aug 25, 2016 8:51 am
It seems like ok wire but the smallest wire I've ever seen to run a f pump
Thu Aug 25, 2016 9:12 am
Thu Aug 25, 2016 10:44 am
that wire looks like it was nicked by a knife or another sharp object or pulled through against a rough edge.
Thu Aug 25, 2016 3:59 pm
I think will cut it open to find the break. It was broken inside the sheathing.
Thu Aug 25, 2016 4:04 pm
Zip tie dat
Thu Aug 25, 2016 4:17 pm
