It is currently Fri Apr 10, 2026 3:11 am
Reply to topic  [ 11 posts ]
 New rig
Post New rig
Been wanting another longtail rig for awhile but hated to spend the money on a new one. Found a 1638gd with 23 gdlt on it today. Frame needs new bushings and shaft and all but im pretty stoked. Ive had godevils mudbuddy and prodrive and going back old school. Really wanted to try a backwater but got this rig for way less than i could have bought just the motor
1638GD with 23GDLT
542 war eagle with 25 yamaha
A few pirogues
Sat Aug 27, 2016 6:54 pm
Post Re: New rig
Congrats! I wouldn't mind having that exact size and combo as a second boat in the fleet.
-Custom pool noodle
-stage 4 water wings
Sat Aug 27, 2016 7:10 pm
Post Re: New rig
I've almost that exact hull , it's a good platform , go anywhere rig . Congrats . You'll probably see. 19-21 mph normal cruising .
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Sat Aug 27, 2016 7:50 pm
Post Re: New rig
I stay in tight timber and small hard bottom rivers. Its gonna be perfect. She is a tiny little thing.
1638GD with 23GDLT
A few pirogues
Sat Aug 27, 2016 8:42 pm
Post Re: New rig
Good deal! Can't beat that recoil start if your battery runs down...you might want to go ahead and invest in a carburetor kit and rebuild that one to avoid problems. Run seafoam/stabil in the gas. A longtail will keep your arms limber; make sure the kill switch works and wear your lanyard in the timber...
Sun Aug 28, 2016 6:37 am
Post Re: New rig
Yeah ive gotta go through it and put new seals and bushings in it. Deff gotta freshen up motor with new plugs and such. Itll be ready for some teal birds soon
1638GD with 23GDLT
A few pirogues
Sun Aug 28, 2016 8:42 am
Post Re: New rig
Stripped old floor out today and about 150lbs of foam. Gotta cut out new floor and get some paint on
1638GD with 23GDLT
A few pirogues
Mon Aug 29, 2016 6:55 pm
Post Re: New rig
I know lots hate the flotation but there is some closed cell flotation/foam that works; I'd rather have some than none. Makes for a quiet, insulated floor. You can go with ss screws/washers so floor is not a real drudgery to remove. The stuff I ripped out of one rear pod on my grizzly was dry after a number of years. Instead of paint I recommend hydro-turf. Look for closeout sheets and specials to save $.
Tue Aug 30, 2016 6:24 am
Post Re: New rig
Oh ill put hydroturf on floor. All my boats have it. I was talking about painting rest of boat.
1638GD with 23GDLT
A few pirogues
Tue Aug 30, 2016 3:51 pm
Post Re: New rig
Longtail needs lots of work. Skeg is cracked and shaft, bearings and prop gotta be replaced.
1638GD with 23GDLT
A few pirogues
Mon Sep 05, 2016 12:07 pm
Post Re: New rig
phoneman7, did you get in touch with GD? As you probably now you need to give them the serial number stamped on the frame and they will give you what you need. Hope you can get it ready for teal season!
Wed Sep 07, 2016 6:38 am
