It is currently Sat Apr 11, 2026 3:56 am
[ 8 posts ] |
2008 Prodrive 36 Clutch Switch
kcbullets
Today my Prodrive kept kicking out of gear. First couple times pushed clutch swith in and pulled back out and it worked. But then after 2-3 times of that it stopped completely. However, I could still use the "momentary engagement button" to get back to dock. I removed the clutch switch and checked with multi-meter and it tests good on continuity.
If the clutch is bad would the momentary engagement button still work? Any advice on checking switch?
| Sun Oct 16, 2016 4:55 pm |
kcbullets
 Re: 2008 Prodrive 36 Clutch Switch
One other thing just for information. I just changed the eng oil and filter, greased, and changed the lower unit lube. I can't imagine this having any impact but odd that no problems before and this happens first time out.
| Sun Oct 16, 2016 5:29 pm |
dead animal
1. unhook battery. 2. get a screwdriver. 3. take cover off the control box where your switch is. 4. look and see if you got a loose wire. 5. if u got a loose wire, unloose it. 6. put it back together or put a new switch in, then put it back together. 7. have fun.
| Sun Oct 16, 2016 7:04 pm |
banded-mallard
| Mon Oct 17, 2016 4:22 am |
mudder
Joined: Sun Jan 25, 2009 11:25 am Posts: 401 Location: Wisconsin
Exact same scenario happened to me a couple of months ago. After diagnosing every which way turned out to a bad clutch ground. Clutch wires were really hot to the touch.
One thing you can do is unhook the two clutch wires at the clutch. make up two wires, spade on one end(clutch) and gator clips for the batter and run direct to the battery. When I knew I had a problem is when I disconnected the ground at the battery and the prop would keep turning. That and the two wires were VERY HOT.
_________________ Phowler Extreme 1848 with 36PDFPR
| Mon Oct 17, 2016 9:04 am |
kcbullets
Thanks for replies. Anyone know part number for clutch switch so I can check at local mower places? Prodrive says their number is PD173, but not cross reference.
| Mon Oct 17, 2016 12:17 pm |
MaXXis85
If the clutch is shorting out you will know. It will show grounded on both pins and also pop the main fuse on the engine harness.
| Mon Oct 17, 2016 2:54 pm |
cledet
Joined: Mon Feb 13, 2012 9:23 am Posts: 35 Location: Metry, LA
_________________ 18' x 54" Uncle J Custom w/ PD 36 FPR and Calen's Stage 2
| Mon Oct 17, 2016 5:50 pm |
[ 8 posts ] |
